Old 02-22-2015, 12:26 AM   #1
'79squared
'79squared's Avatar
Temp sender issue
So I have tried two temp senders http://www.oreillyauto.com/site/c/de...?keyword=wt359 and http://www.summitracing.com/parts/smp-ts76 and both are reading my temp at about 260 (pegged) when warmed up. I know my motor is not running this hot nor over heating. I dont want the sender to be in the intake (1/2"npt) so I am running the (3/8"npt) in the head. Aluminum heads with headers. Does anyone know which sender will not read so high? Or is there a way to maybe put in a resistor or something? I think the gauge is out of an '86 but I'm not 100% sure. The gauge is the one with the temp picture, not the word. If that makes any difference. Thanks and if I've left out something let me know.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 02-22-2015, 02:18 AM   #2
rich weyand
rich weyand's Avatar
Re: Temp sender issue
See this: http://67-72chevytrucks.com/vboard/s...31&postcount=5
You need a GM #8993146 or equivalent. That Summit TS76 part cross-references, but aftermarket and auto parts stores senders are sort of generic, and not a good match for the gauge. Engine doesn't matter, just the gauge, because the gauge and the sender have to agree on how much resistance equals how many degrees. You are best off with an NOS part.
Just poking around on Google (GM #8993146), I find some possibilities.
http://www.ebay.com/itm/NEW-GM-TEMPE...-/400339842388
http://jnjvette.com/store/index.php?...product_id=632
http://www.oldsobsolete.com/products...h-nos-8993146/
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-22-2015, 10:38 AM   #3
'79squared
'79squared's Avatar
I'll have to give that a shot thanks. Off to order number 3 haha.
1979 SWB 350/350
Old 02-22-2015, 11:35 AM   #4
greg64
greg64's Avatar
If you disconnect the sensor wire, with the ignition key on (gauge has power), what does the gauge show? It should read cold. If it sticks at 260, I think the sensor wire is grounding out somewhere.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-22-2015, 11:43 AM   #5
rich weyand
BTW, if the gauge was replaced at some point with a reproduction gauge, then all bets are off. In that case, you might have to experiment with different senders to find the right one. But for the factory-installed gauge in years 1979 and later, that's the sender.
Rich Weyand
1978 K10 RCSB DD.
Old 02-22-2015, 03:42 PM   #6
'79squared
'79squared's Avatar
We've tested the gauge. It works. Plus I can watch it go from 0 to 260 on warm up and then when I drive it I can see the temp fluctuate when the water is cycling. I know it works. The gauge was taken from a 86 donor dash. I just ordered #8993146 so I will know soon if I have hit the mark or I own 3 that all read to high lmao!
1979 SWB 350/350
Old 02-23-2015, 12:54 PM   #7
mattcrp1
mattcrp1's Avatar
I am dealing with a temp sender retro fit issue my self. I have found the dash gauge makes a difference. There are about 3-4 different senders.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-23-2015, 08:06 PM   #8
hatzie
Moderator
hatzie's Avatar
Correct
The part # referenced above is correct for @ 1983 - 1991 CK & RV squares and some of the 88-91 T400 CK chassis trucks. GM probably used it on at least the B body cars too...
Prior to 1983 it gets dicy finding the correct sender. There were several different senders in 3/8" and 1/2" and several different connectors for them.
The Nail Head 1/2" dia transducer sender that GM used on everything from the C3 Vettes to the CK trucks is discontinued and nothing in the aftermarket or from GM properly matches the Temp to OHMS profile of the original transducer. There are a few that are close
This is a pretty good GM temp gauge troubleshooting guide from Wilcox Corvette.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
