Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-22-2015, 04:09 AM   #1
BigDan3131
BigDan3131's Avatar
Question 4L80E To Shift or Not To Shift???
I've been making progress on my truck and pulled the stock glide out today and I started thinking about whether or not to add a shifter or just use the column.
So those of you with 4L80E's do you just leave it in Drive when you race and adjust everything from either the controller for your shift points or thru your ecm? It will save me a few hundred dollars to not have to put one in [a shifter] and fab a stand for it.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-27-2015, 10:35 PM   #2
djracer
djracer's Avatar
Re: 4L80E To Shift or Not To Shift???
I have not raced with an 80 but I would think letting it shift itself would be more consistent!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-28-2015, 08:45 AM   #3
Heavymetl
Program it to shift electronically. It does take some "tuning", as there can be a 2-300 rpm delay between commanded shift and actual shift.
I also used the Lokar adjustable shift rod on my 1970 C10/4L80E. Works awesome! Obviously though the 3 speed indicator is incorrect but eh...no worries about that from me
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 03-28-2015, 06:18 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I like having a shifter for a couple reasons. First, mine is a weird Kilduff shifter, so I just like the hot rod way it looks.
Before I had a stall, I like having it to hold a gear when you were playing around in it. I also like being able to pop to neutral and coast out easy, or being able to put it into 2 when I'm in stop and go traffic and just put along.
My truck gets street miles as well, so that made the shifter practical not performance.
Any time its been going for all out time, I just let it do its own thing.
On the same vein of thinking, what about o/d? Do yall go straight Drive, or o/d off?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-28-2015, 11:04 PM   #5
BigDan3131
BigDan3131's Avatar
Now that that's been answered Do I just go with the TCI controller or the "Black Box" controller that all gears are manual shift? I will be using a shifter now since even the Lokar shifters in either the rod style or cable need fine tuning. My city driving is maybe 2-5 miles a day compared to freeway driving which is 32+ round trip, that's why I mentioned the black box controller. I will be adding both a very large cooler and an extra deep pan.
Old 03-28-2015, 11:30 PM   #6
tranz am
tranz am's Avatar
have been recently very interested in the 4L80e swap as well so I've been doing my homework. TCI sells a controller that will work but I have determined that there is a better controller on the market check out www.usshift.com.
also if you're interested in a fully automatic trans brake valve body check out http://www.jakesperformance.com/site...%2F4L80E.html#
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-30-2015, 02:16 AM   #7
BigDan3131
BigDan3131's Avatar
The only issue I saw with the us shift model is its about $175 more than the TCI unit and the Jakes valve body I already knew about.
