Old 02-24-2015, 04:09 PM   #1
jackedup
Lowering with rear leaf springs
So Im wanting to lower my 71 c10 3-4 inches. the problem Im running into is there are no shackles or hangers that I can find for a 71 c10 w/ leaf springs. I don't want to heavily modify anything to lower it. Does anyone know of any products out there? Ive considered removing all but the longest leaf on my springs and swapping the shocks out for coil over shocks that area adjustable. Thoughts?
jackedup is offline   Reply With Quote
Old 02-24-2015, 05:21 PM   #2
terry b
terry b's Avatar
Re: Lowering with rear leaf springs
You remove to many leafs and she will wheel hop like a b---h. If you ran ladder bars with air bags you might get away with only main spring.
terry b is offline   Reply With Quote
Old 02-24-2015, 05:23 PM   #3
jackedup
im hoping the addition of coil over shocks would prevent that. not sure though.
Old 02-24-2015, 05:28 PM   #4
john
member #16
john's Avatar
gmcpauls has some lowering springs and shackles. Welcome to the board.
http://www.gmcpauls.com/lowering_springs_&_parts.htm
john is offline   Reply With Quote
Old 02-24-2015, 05:53 PM   #5
jackedup
Thumbs up Re: Lowering with rear leaf springs
Checked out GMC Pauls. Perfect! mystery solved!
Thanks for the info.
Old 02-24-2015, 06:48 PM   #6
Mike C
Mike C's Avatar
Early Classic Enterprises does as well. Choices are shackles, drop springs, drop springs and shackles, or flip kit.
I flipped mine with a DJM kit from Summit Racing. Probably the least expensive method also gives the most drop. My truck has the 4 leaf + overload setup instead of the 3 + overload base spring so may have had a little more arch than the standard setup.
I pulled the overload because it was interfering with the CalTracs. And speaking of CalTrac, in addition to the traction bars (flipped or not flipped) they offer their split leaf spring as well I think. If you are going to try and make big power, I'd go with their spring and the CalTrac bars.
I did 2 1/2" disc spindles in the front with 2" springs for 4.5" drop in the front and the flip netted about 7" of drop maybe a tic more in the rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
leaf, lowered, shackles
