Old 02-24-2015, 11:16 PM   #1
ProudSoul
ProudSoul's Avatar
1963 Texas Time Travelin' Machine
Bought this 1963 SWB BBW with a small block 400 and Powerglide tranny in Wylie, Tx about a year ago and while I've been a big time lurker on this site I haven't made much contribution so I thought I'd share what changes I've made.
Keep in mind I bought this truck during my senior year of college (broke as a joke) and had minimal wrenching experience so it has been a huge learning experience and I could not have done it without this forum
Also, note that I don't intended to blow my truck apart and rebuild it, this is more of a fix it up, drive it, fix it up some more kind of project
Attempted to drive her home(60 miles) and overheated her pretty bad and had to tow it the last 30 miles. Here's day 1.
First Thing I did was clean her up a bit and do some basic stuff like fuel filter, air cleaner, oil, trans fluid/filter, chase some bad grounds, and add some peep mirrors!
Added a cheap mechless headunit under the dash with some 6x9's behind the seat. Also added some gauges. Made some 7.62 knobs for the old radio
Swapped the old master cylinder for a dual pot MC with all new lines
Decided to go for the bare metal look on the door panels
Truck still had the original shocks on the front so I swapped them for some KYB's
Rebuilt steering box and new tie rods to fix the sloppy steering
Hand painted the grill letters
Headrests removed and a mexi blanket over the seat
Made a makeshift fan shroud out of aluminum flashing
Nice day to take my 61 huffy for a ride
Next up I put in some new balljoints, shaved the bumpstops, cut one coil off the front springs, and topped it off with an alignment.
To address the rear I added 2 inch blocks and cut one coil
My steering wheel would turn your hands black everytime you touched it so I took it off and painted it with appliance epoxy and it has held up great! Also painted and added the shift knob
Having that ratty shop truck look I decided to black out the window with some 5%
Painted the tailgate letters and went over it with some paint thinner to give it that patina look. I also painted in between the trim and hacked another half coil off the front. Added some half moon eyelid covers about this time.
I just had to add some Texas flare to this truck
I wasn't happy with the 1 and 1/2 cut coils on the front they didn't seat right and would fall out on full lift so I decided to just bag it. Being on a budget I found some lower control arms for $50 to cup. I cut everything out and gave it to my buddy to weld. I also built my own 4 way air ride controls using 3/8 lines and ball valves.
I also got some new u-bolts for the lower control arms since the old ones are prone to breaking
Viar 444c and 3 gallon tank
My buddy Grant is trying to get into pinstriping so I let him lay some lines down on my air cleaner. Not bad for his 4th or 5th time
Got some airlift dominators for the front, the cheap ass chassis tech bags leak and the replacements I got from them leak too so I'll just put them on the back for now.
I'm not even bagged in the back and I rubbed a hole in the hose going the fuel filler neck in the wheel tub. Decided I would just make a trap door in the bed and figure out some kind of filler underneath it.
Here is how she's sitting right now. I had to cut the rear springs out as the bolts were rusted solid. Need to drill holes in the frame for bags and run some air line back there.
I'll be sure to post updates as I go
ProudSoul is offline   Reply With Quote
Old 02-24-2015, 11:40 PM   #2
flashed
Re: 1963 Texas Time Travelin' Machine
I like what you have done so far ,will keep watching as you go forward .
flashed is offline   Reply With Quote
Old 02-25-2015, 12:53 AM   #3
63chevyman
Looks like a great score on the truck. Keep up the progress
63chevyman is offline   Reply With Quote
Old 02-25-2015, 04:25 AM   #4
Grizz1963
Grizz1963's Avatar
Talk about coming in with a BANG !!!
That is a great first post.
You have done so much great stuff already.
If you were on an unlimited budget, I would love to see what you created.
I love every aspect of your truck.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-25-2015, 11:28 AM   #5
ProudSoul
ProudSoul's Avatar
Thanks for the kind words guys! I'll be sure to keep posting as I go.
Old 02-25-2015, 11:33 AM   #6
Ta2Don
Ta2Don's Avatar
Great start...
Gotta agree about this board boosting confidence...
I bought my 65 sans engine with the plans of dropping in a small block and driving the wheels off... Instead, I blew it apart and found bent frame and the saga continues...
Enjoy and keep up the great work...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-25-2015, 01:50 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Project is sweet. Subscribed.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-25-2015, 01:51 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. Nice progress and to see you know your priorities.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-25-2015, 05:15 PM   #9
Justin@EntropyRad
Justin@EntropyRad's Avatar
You had me at Mexi blanket and 7.62 knobs!!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 02-25-2015, 05:34 PM   #10
earl84
Some great ideas used on your truck! Being an ex-Army tanker, I LOVE the 7.62 radio knobs. Appliance epoxy on the steering wheel is a great idea, and has to be durable as heck. This is th best forum on the Internet, no doubt about it. Lookin' good, keep it up.
earl84 is offline   Reply With Quote
Old 02-26-2015, 01:38 AM   #11
Vics63Chevy
Vics63Chevy's Avatar
b1tchin' truck
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
Old 02-26-2015, 11:13 AM   #12
aggie91
I'm just glad to be here!
aggie91's Avatar
Welcome to the forum. Love the truck and what you have done so far.
I noticed the air dam under the bumper. Can you tell us more about it?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-26-2015, 01:33 PM   #13
Welcome aboard. Your truck looked great to begin with, but you have really made it come out!
Palf70Step is online now   Reply With Quote
Old 02-26-2015, 04:00 PM   #14
joedoh
joedoh's Avatar
nice work, is that a 88-99 lower valance under the bumper? I worked with an aero guy who told me to lower my 99 suburban and get that valance as close as possible to the ground for best mpg. seeing it on there, it looks good!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-26-2015, 08:36 PM   #15
ProudSoul
ProudSoul's Avatar
Originally Posted by Ta2Don View Post
Great start...
Originally Posted by Vics63Chevy View Post
b1tchin' truck
Thanks Guys!
Old 02-26-2015, 08:38 PM   #16
ProudSoul
ProudSoul's Avatar
Haha thanks. I may have to post some pics of my 7.62 babies and the truck
Old 02-26-2015, 08:44 PM   #17
ProudSoul
ProudSoul's Avatar
Yes, you guessed correctly! The valence looks pretty good from the front but there's a gap when viewing it from the side between the valence and the front fender. I may trim it or try to heat and bend it to follow the lines of the bumper. I've seen a lot 67-72 trucks use this valence so I gave it a shot for 30 bucks off ebay I can't complain.
Old 02-27-2015, 04:21 AM   #18
Grizz1963
Grizz1963's Avatar
I forgot to say, I personally love the seat as well.
Those split seats look great and are probably good to live with.
Do you know what it was from?
And if people recognise it, do they come in any dark colours?
I am thinking of one upholstered the same as the seat in my truck.
Old 02-27-2015, 10:08 AM   #19
Ta2Don
Ta2Don's Avatar
Grizz, those seats appear to be out of 88-9? Chevy trucks/suburban and they come in a variety of colors... My 90 DD has the dark red one... I believe headrests were added in 91...
DON
Proverbs 27:17
Old 02-27-2015, 07:13 PM   #20
Head rest were 92.
They are great seats Grizz. Very comfortable. I am getting ready to take the ones from my 94 and put in the 64.
Now back to our regularly scheduled build thread.
Old 03-14-2015, 07:17 PM   #21
ProudSoul
ProudSoul's Avatar
Well finally got my rear bags mounted. Need to get some narrower wheels as these 15x10s wont let me go lower than the bumpstops.
Thought I would dump some oil in her real quick and go cruise around but I ran into a problem with my oil filter and I can't believe that I am mentioning something as simple as an oil filter in this thread but its a huge pain in the
the filter is stuck on there and I've already broken 3 filter wrenches trying to get it off. Breaker bar, impact, nothing is working. Might have to take the headers off and perform screwdriver surgery
Old 03-15-2015, 12:46 AM   #22
Captainfab
60-66 Nut
Yep, oil filters can be a big PITA when the previous installer did not lubricate the seal and tightened the crap out of it. Have you tried a band style filter wrench?
Your truck is looking good
Old 03-15-2015, 09:40 AM   #23
flashed
Can you get a big pair of Channel locks in there and get hold of it ?
Old 03-15-2015, 08:12 PM   #24
Elliot949
Elliot949's Avatar
Next to my 67... The 63 SWB is my favorite... I love your truck...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 04-05-2015, 12:03 PM   #25
ProudSoul
ProudSoul's Avatar
Nope unfortunately the channel locks aren't working, I went ahead and ordered a new oil filter adapter. Just going to rip the filter apart and un bolt the old adapter.
Thank you!
