65 K-10 not quite orginal
I have been lurking here for a few years. What a great source of info. I bought a 65 K-10 about 4 1/2 years ago. The first pic is the day I brought it home. Jan of 2014 my son and I started tearing it down, we are doing a complete frame off rebuild and enhancement of it, I want it to look mostly stock except for the colors to the unknowing. We have been busy all year. I will be adding more info shortly. I just figured out how to add pictures and lets face it without pictures this is not much fun.
Post Whore
![]() Join Date: Mar 2013
Re: 65 K-10 not quite orginal
Looking forward to watching the build.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Here are some pictures of the frame once I completed the rust repair, and mocking up the axles. We went with 4:11 gears and posi's front and rear. The following pictures are of the 406 small block I had built for in the truck
![]() Join Date: Aug 2008
Looks awesome! Can't wait to see this story unfold.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Here are a few pictures of when I fired the motor and ran it for break-in. My neighbors love me. I am blessed to live in a town we pushed the rolling chassis with the motor, transmission, transfer case etc... out into the driveway on a sunny Saturday afternoon before hunting seasons started. I had a piece of plywood sitting on the the frame with the instrument cluster and battery, all connected. We lit it off and it fired quickly, 475 extremely healthy horses sounds very very good. We only had dumps on the open headers. We ran it for 20 minutes like that at 2000 RPM. Then I had to play with the throttle a little. OK, so we played with the throttle a lot. The last picture is the day we set the cab back on to start mocking it up. All new floors, cab corners, etc... It was a PA truck there was lots of rust repair.
Looks great..
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Assembled the truck with the original hood (black), pushed it outside for the second pic with the hood we are using last fall right before the snow started. Then my winter project was to fix more rust (mostly in the bed).
Very nice!!!
Very very nice job man.
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
Some picture of the outside as it was before I started to tear it down for the final bodywork before paint. Please note my faux wood painted tailgate, (was in the garage to late that night...) it will all get sanded off. Fit a solid antenna from a 72 in the passenger cowl panel. Factory aluminum grill all redone, moved the gas tank to the rear (still have to cut a filler door into the side). Lots of work here still hopefully have it painted by late April or early May. Mango Tango and Silver metallic two tone.
Interior pictures! We cut out the original ash tray welded the hole shut and drilled two holes in the center for the ac also drilled holes on both outside edges for two more ac outlets. Made a plate and welded it in to fit the Retrosound radio. Mounted a new 67-72 steering column. Seats out of a 2004 Silverado moved as far back in the cab as possible. Custom fit Lokar gas and brake pedals mounted so they fit me.
Motor shots. This is as together as its got. Started to tear her back down to paint. I will try to keep more current with the photos. Starting the last bit of cutting and modifying to the body today, hopefully get a fuel filler door installed in the bedside. Then smooth everything out and making it pretty.
#13 |
Things are progressing nicely!
Looking forward to future updates! |
#14 |
Finally got up the courage to cut the hole in the bedside for the filler door. I am confident in my welds in anything thicker than sheet metal. So I used a panel bonder last night, along with screws to hold it. Headed to the garage now going to remove the screws and plug weld the holes.
#15 |
Score of the build, 15 X 8 CUCV wheels. I found a guy over a year ago that has a junk CUCV he bought for the motor. He told me then the wheels would be mine when he gets to it. Got the call this week.
#16 |
Some pictures of the cover I made inside my bed to clear my filler neck and door on the bedside.
#17 |
A little teaser of color!
#18 |
Post Whore
Very nice!
#19 |
Love that color, really looks good on our style body
#20 |
WOW!! Nice job. going to look great.
1961 chevy K10 my build is------------61K10 build |
#21 |
Nice truck!
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
#22 |
its coming along nicely =0)
dont want to hear excuses, i want to hear solution(s) |
#23 |
Been busy with life but have made some progress with alittle help from a good friend and painter!
#24 |
Few more pictures, reassembly cant happen to soon!
#25 |
You definitely have excellent fabrication skills! I wish I wasn't under the weather right now or I'd be out in the garage. Keep up the great work!
Mike. |
