03-15-2015, 07:26 AM | #1 |
67-72 front crossmember VS squarebody
First C10 brought up if it would be possible to put a squarebody front crossmemebr in a 67-72 frame since the squarebody can accomidate a LS engine while the 67-72 needs a custom crossmember
I cant imagine no one has thought of trying this up until now but I havent seen any chatter on it. COuld one fit or be made to fit with some slight modification? Would seem to be much easier and less expensive than the custom ones being offered |
03-15-2015, 11:16 AM | #2 |
Currently Blazerless
Re: 67-72 front crossmember VS squarebody
It's been done before, I know there are a few on here that used them in there big block conversions. It takes a little trimming and drilling, I posted an article from an old 4x4 Power magazine on how to do it but that's been years ago, I'll see if I can find it.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-16-2015, 06:31 PM | #3 |
That would be great if you can find the article.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-16-2015, 11:08 PM | #4 |
I haven't found any info to confirm it but I think its safe to say it'll work since you can swap a 73-87 2wd engine crossmember into a 67-72 2wd because the frame rails are the same width at the engine crossmember.
Do the 73-87 guys have to modify their engine crossmembers for LS swaps?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
03-16-2015, 11:21 PM | #5 |
No they don't. Sometimes a little tight for header which I could care less about but headers are tight in any scenario
03-17-2015, 05:49 PM | #6 |
Here's one I'm aware of 72 2wd to 4x conversion using the later cross member http://67-72chevytrucks.com/vboard/s...9&postcount=53
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
03-17-2015, 06:10 PM | #7 | |
03-17-2015, 06:49 PM | #8 |
I would agree but have noticed that they are very similar. I've got one from a 73 K5 and an 84 K30 both look a lot like the 87 K30 used in the example I posted earlier. Differences I noticed had to do with strength extra bolts, tabs, etc but same basic shapes.
03-17-2015, 07:00 PM | #9 | |
Big block vs small block? |
03-17-2015, 07:13 PM | #10 |
Small block, I believe the BB versions have an additional hole pattern in the stand to accept a 4th bolt for the BB motor mount. Just my observation hope it helps.
03-17-2015, 09:17 PM | #11 |
This is the best picture I could find of the crossmember on my 76. The actual crossmember part was virtually straight from one side to the other, it might have had just a slight bend. Then the motor mount pieces sat right behind the crossmember. And that was a factory small block truck.
But regardless of whether they are straight or angled they look like they'd work real nice for an LS engine.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 03-17-2015 at 10:18 PM. |
03-18-2015, 01:17 AM | #12 |
So looking at your picture it makes sense why the LS won't work in the 67-72 k series
Your crossmemeber is basically straight and perfectly horizontal as ours are more "u" shaped and sits farther back closer to the larger part of the oil pan So in my uneducated non mechanical opinion this is a viable option. But for the cost of $400 for a dirty dingo is it worth the headache of customizing? Also in looking at my 72 k10 my crossmember appears to be bolted I. As opposed to riveted does this sound correct? |
03-19-2015, 05:39 PM | #13 |
Sorry guys I went back thru the archives and couldn't find where I had posted that article so I found the original magazine and scanned it again.
Hope this helps.
03-19-2015, 09:02 PM | #14 |
Thank you for finding that
03-20-2015, 01:19 AM | #15 |
Thank you for the info......I think I am going to try this with an LS build.
03-20-2015, 01:39 AM | #16 |
04-05-2015, 11:16 PM | #17 |
This is he close up of the stock 67-72 engine crossmember and a 73 up square body
04-05-2015, 11:22 PM | #18 |
This is what will needed to cut because the 91 burb frame that this came from. It is 5-1/2" and the k20 frame I am using is 5".
The motor mount stand is upside down and bolted to the table so I can cut it tomorrow.
04-06-2015, 12:36 PM | #19 |
Looks pretty slick, great info!! I'm sure this will make the LS (or a BB) swap go easy.
04-11-2015, 12:11 PM | #20 |
Here are some pictures of the crossmember that was in my 67 GMC with the 305 V6. Anyone know if this is the stock crossmember, or a 73-87?
67 GMC K2500. 305D V6, 4 spd, rotted wood bed, and lots of rust!! WTB: Eaton HO 4:10 or 4:11 tapered beaing gearset, or complete 3rd of either style bearing in the 4:10 ratio |
04-11-2015, 12:14 PM | #21 |
well to my uneducated eyes it surely looks different than the V8 crossmembers of that vintage
First? |
04-11-2015, 02:02 PM | #22 |
It deffenently is different than the square body v8 cross member. In my earlier picture you can see the stock 67-72 4wd crossmember (black)and the square body( in primer) on top of it. My frame has the bolt holes where your v6 crossmember is bolted. So it maybe a stock v6 crossmember. I am not familiar with the v6 setups. Hopefully someone can chime in. The v6 cross member if stock looks farther forward then my stock one. Below is not a very good picture but you can see the holes in my frame that would accept your v6 crossmember(I think)
04-11-2015, 02:12 PM | #23 |
Thought I would update this thread a little. I had to cut down the motor mount perches as the sonar frame was 1/2" thicker. So I cut it down and added a piece of 1/4" flat stock. Welded it up. I will post a few more picture.
04-11-2015, 02:14 PM | #24 |
Cut down.
04-11-2015, 02:16 PM | #25 |
Ready to clean up with the sanding disc and check fitment
