03-15-2015, 04:21 PM | #1 |
blazer top rail holes?
Bought a 72 blazer without a top. The top bed rails appear to have way too many holes for whats necessary to mount the top. I need to know what ones I need to fill to make it correct. The ones with the captured nut are a no brainer but how many others are there. A picture would be nice.
03-15-2015, 04:24 PM | #2 |
Re: blazer top rail holes?
One set is for a single wall and the other set is for a double wall.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-15-2015, 05:35 PM | #3 |
Most 72's have a single wall top that bolt from the top down so you need the ones with the caged nut. Double (had single here) wall top bolts from the bottom up and would need the thru holes so it will depend on which top you have.
03-15-2015, 05:40 PM | #4 |
SKINNY TIRES RULE!
If you are going to use a soft top, you may need more of the holes. You should make sure you know what top(s) you are going to use before filling the holes.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-15-2015, 09:24 PM | #5 |
My 72 has a double wall.
But agree, it could be multiple things. Single, double, or was drilled for a soft top.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
03-15-2015, 09:30 PM | #6 |
I agree with the others. 1972's are unique, they have hole for both double and single wall tops.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-16-2015, 09:31 AM | #7 |
2WD Jimmy
03-16-2015, 01:32 PM | #8 |
urban fourwheelin
Not all 72's have this feature.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
03-16-2015, 07:20 PM | #9 |
Are there pins in the top to help line it up with the bed rails and how many total holes are there for both type tops.
03-16-2015, 09:51 PM | #10 |
My 72 only has holes for a single wall. I've never see them with both unless someone modified the holes. More than likely it was done because they couldn't find a single wall so they stuck on a double wall which are easier to find and as simple as drilling some holes. The original holes are also oval shaped for adjustment.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
03-17-2015, 09:28 AM | #11 | |
2WD Jimmy
03-17-2015, 09:51 AM | #12 |
My 72 has both sets of factory holes as well.
03-17-2015, 06:42 PM | #13 |
How many factory holes are there so I can eliminate the ones that aren't needed.
03-17-2015, 08:33 PM | #14 |
My 71 with a double wall top has 6 holes on each bedside. Each 13" apart.
