03-16-2015, 04:22 PM | #1 |
'59 Apache: Need help with Front Cab Floor support Brackets
Does anyone know how to replace the front cab floor support brackets in a 1959 Chevy Apache stepside? I think they are also called Front Cab mounts maybe. I have the assembly manual and can't find anything about them.
Thanks, Stan |
03-17-2015, 10:13 AM | #2 |
Re: '59 Apache: Need help with Front Cab Floor support Brackets
they sell them in the LMCtruck catalog.
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
03-17-2015, 11:05 AM | #3 |
I saw those but how do you replace them?
03-17-2015, 11:56 AM | #4 |
Cut yours out, I think they are spot welded in there. So you may have to use a wire brush on the inside of the floorboard to see the spot welds and drill them out. Use a pry bar and start working.
03-17-2015, 12:44 PM | #5 |
So are they spot welded to the floor pan or the crossmemeber? Meaning do the just rest on the crossmember?
03-17-2015, 01:35 PM | #6 |
They are spot welded to the firewall/toeboard (actually the firewall/toeboard is spot welded to the crossmember). However, the floor is also spot welded to the firewall/toeboard just behind it, so you will likely have to drill those out to. I just replaced my firewall/toeboard with a new one from Dynacorn (excellent fit), but since I still had great front mounting pads and crossmember, just cut the new one out around them and flush welded - now much stronger than original. Cheers, Jim
03-17-2015, 02:37 PM | #7 |
Thanks All!!!!
