Old 03-19-2015, 09:54 AM   #1
$20071k10
$20071k10's Avatar
71 power steering swap?
ok this seams to be a very covered topic for 2wd's! I want to convert my 71 k10 to power steering I have a 73 k20 parts truck. will the box be a direct bolt on? if not what will I need to install it? will the 73 350 pump bracket's bolt to the 71 350? will I have to convert to all the 73 accessories IE move the alt and all that? thanks in advance
Brian
$20071k10 is offline   Reply With Quote
Old 03-19-2015, 07:33 PM   #2
ryanroo
ryanroo's Avatar
Re: 71 power steering swap?
The box will bolt to the frame. its a the exact same box they used in the earlier trucks.
the 73 front drive accessories will be for a long water pump. if you have the OE set up on the 71, it will be short pump. the steering pump is the same, the pulley may be different and the mount bracket will be different. if you want to run the whole shebang from the 73, you will need to swap the entire set up from one to the other. bits and pieces dont intermingle on the front drive stuff.
there is a year break in the late 70s for steering fittings. the early ones are std. flare and the later stuff is all metric o-ring. yours should be std. and would be the same as a stock 71, so if you retain the short water pump and related brackets, the line set from a 71 would be a direct fit. the lines from the 73 will be different, but still may work.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-19-2015, 08:20 PM   #3
$20071k10
$20071k10's Avatar
Thanks Ryan so if I want to keep my alt on th drivers side I will need to find 67-72 brackets right? I have read that it is bad to mismatch pumps and boxes so if I can find the right brackets for the 71 will a 71 pump work with a 73 box?
Brian
