Old 03-19-2015, 11:17 PM   #1
Calvin66c10
LS swap with manual transmission
Hello there,
I have a 66 c10 shortbox that I bought a 6.0L lq9 for and have installed a comp cam, ls1 heads and likely going to put a carb kit on it. Has anybody installed an LS engine with a 5 or 6 speed manual? I'm looking to keep my bench seat and that's the main obstacle. Currently I have a 355 ci (375hp) engine with a T5 Camaro (s10 tailstock swap) trans in it. Looking for a trans that I can beat on a little. I'm expecting the finished motor to have 450-500hp. Any suggestions for transmissions would be great thanks.
Calvin66c10 is offline   Reply With Quote
Old 03-20-2015, 12:47 AM   #2
Captainfab
60-66 Nut
Re: LS swap with manual transmission
The LS1's and LS2's did come backed with the T56's but you will have to relocate the shifter to be able to keep your bench seat. A Tremec TKO500 or 600 would work equally as well, but there again the shifter will need to be moved from the standard location. There are kits available to relocate the shifter in either trans.
The T56 will require a hydraulic clutch, which I do make a conversion kit for, for the '63-'66 trucks.
Old 03-20-2015, 09:35 PM   #3
TwinsSpeedShop
I have a 5.3/T56 combo with bucket seats. The shifter would not clear the bench seat in the stock location. There are kits to move it to the inspection plate location, but it takes almost a complete teardown of the the trans to put in. There are companies that could rebuild one, beef it up for you, and do the shifter mod at the same time.
TwinsSpeedShop is offline   Reply With Quote
Old 03-20-2015, 09:51 PM   #4
akdg87
akdg87's Avatar
there's the option of mating it an older style transmission such as a muncie.
i am putting a carb L92 in a older transam with a muncie m-22, its pretty straightforward.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 03-25-2015, 09:50 PM   #5
TR65
TR65's Avatar
Calvin,
I put a T56 / hydraulic clutch in my 65 with bench seat. See threads referenced in my build. I really enjoy the T56. Several years in use, no trouble.
Good luck, TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
