04-02-2015, 10:54 PM | #1 |
My engine swap... Having questions
Ok so this is my first engine swap. Probably the biggest project I've tackled on this truck. The old was a 454 out of a 76? Suburban. Putting in a 327/355 (327 with 350 crank heads and bored over. Also putting in a 700r4.
I just about have every thing buttoned up when I came across these wires that plugged into the electric choke? Of my old rochester. The edelbrock I put in has manual choke. So I'm wondering what to do with these wires. Do I just tuck em and hide em? Do they serve another purpose? Here is a pic of the ones I'm talking about. There are 3 wires
HOTROD HOODLUM |
04-02-2015, 11:00 PM | #2 |
Re: My engine swap... Having questions
Also here are some progress pics.
HOTROD HOODLUM |
04-02-2015, 11:02 PM | #3 |
Cleanin it up
HOTROD HOODLUM |
04-02-2015, 11:03 PM | #4 |
My daniAnn small-block.
HOTROD HOODLUM |
04-02-2015, 11:04 PM | #5 |
Fabbed up york 210 bracket
HOTROD HOODLUM |
04-03-2015, 07:31 AM | #6 |
That's looking good! Love your shifter knob.
04-03-2015, 10:21 AM | #7 | |
Both a 327 and 350 have 4" bore. The different in cubic inch is in the stroke of the crank. 327 has 3.25" stroke, the 350 has 3.48" stroke. there is a piston pin height difference from a 327 to 350, but the connecting rods will be the same. So, Im assuming you just used a 350 crank and 350 pistons with the stock 327/350 rods (5.7" long). So, long story short. You have a 350 (using 68/69 originally 327 block). Was there something wrong with the 327 crank? Do you still have it?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 04-03-2015 at 11:26 AM. |
04-03-2015, 12:04 PM | #8 |
Hmm. Interesting. Shop that built it says it's a 350 bored .030 over making it a 355.1 It's a 1967 small journal 327 with a custome steel 350 crank and old school 350 heads mild cam and domed pistons. Not sure about old 327 crank as I didn't build it.
Any input on those wires any body?
HOTROD HOODLUM |
04-03-2015, 12:37 PM | #9 | |
I can't see the wires good enough in the picture, maybe if you took a close-up of the ends of the wires to possibly identify the connectors? |
04-03-2015, 01:48 PM | #10 | |
I can't quite see on the motor you have pictured with the AC bracket mock up, but... just behind the water pump, above the timing cover and below the intake. there is a bubbled or rounded portion of the block... is there a square headed little bolt sticking out at an angle or is there nothing there? such as in this photo, this is looking up at an angle from in front of the fuel pump area (weird angle photo) http://i54.tinypic.com/2502mjc.jpg or http://www.phoenixengine.com/Graphic...ines/24-08.jpg (notice the little piece just above the timing cover and just below the intake) Also, is there a breather pipe embossment hole next to the distributor in the back or no? such as in this photo: http://img98.imageshack.us/img98/279...imagelarge.jpg or http://www.macswebs.com/richl79/65L79/l79drvreartop.jpg
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 04-03-2015 at 02:15 PM. |
04-03-2015, 02:04 PM | #11 |
It's a custom. Crank. It's shorter to fit a small journal. I looked up the block number. Its a 1967 block. Canister style so most likely out of a truck. I'm pretty sure the camaros had spin ons. I will take a close up pic of the harness when I get home.
HOTROD HOODLUM |
04-03-2015, 02:18 PM | #12 |
They must have reground a large journal crank to the smaller journal. I have never known anyone to do that.
As far as your choke wires issue. What carb are you running? The first image shows a big block with a Q-jet, the AC bracket image shows an edelbrock. The first picture, is not a picture in the location of the choke. The choke is on the passenger side middle of the carb. The solenoid in the picture is some emission related solenoid or an AC idle kick-up solenoid.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-03-2015, 03:40 PM | #13 |
Yeah it's basically a shortened steel long journal crank from what I understand. It's been done before.
Here is a close up pic of the wires. They are brown black and blue. The harness only has 2 femal plugs in it. So 2 wires go into 1. Let me know what you guys think. I'd really like to clean up this wiring before I start it up next weekend.
HOTROD HOODLUM |
04-03-2015, 03:55 PM | #14 |
I have reground mains on a few 350 cranks where customers wanted to keep their small journal block. More options going to the 2.100 diameter rods.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
04-03-2015, 04:23 PM | #15 |
That wire should be capped off and hidden. It looks like either an idle kick up for AC or it could have been an idle stop or "anti-diesel" solenoid. Either way its not the choke, has nothing to do with the choke, and will not be useful on your new carb.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
04-03-2015, 06:37 PM | #16 |
I will second on the A/C solenoid for high idle. That was my thought as I went through the thread then went back and looked and said to myself, Self that is the A/C idle solenoid.
04-04-2015, 01:36 AM | #17 |
Great. Thanks for the help guys.
HOTROD HOODLUM |
04-04-2015, 08:08 AM | #18 |
what color is your engine painted?
04-04-2015, 02:40 PM | #19 |
It's vht burnt metalic copper.
HOTROD HOODLUM |
04-04-2015, 09:45 PM | #20 |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-04-2015, 09:50 PM | #21 |
My first thought was cruise control but it was just a guess..
04-04-2015, 11:37 PM | #22 |
The solenoid for CC is usually remote from the carb and there is just an additional cable to the throttle linkage, at least with most of the ones I have seen added aftermarket.
04-04-2015, 11:50 PM | #23 |
Yup cap em off and tuck em out of sight.
1967custom |
