help no start need to goto work
1972 c20 pickup I have no power at all and hooked up jumpers before wife left to see if it needed a jump. Still nothing. Nothing turns on
Re: help no start need to goto work
Its a 402 BBC /400 turbo I have no power at all. No lights nothing like the battery is dead but isn't.
Check the ground wire that comes off your battery and make sure it has a good connection to the frame.
Ground wire from bat runs to block and is tight.
Keep checking your connections. Sounds as though you have a bad ground somewhere. What about your hot wire that goes to the starter?
I'm trying to remember right off, doesn't the positive wire come off the battery and go to the passenger fender wall to a fuseable link? If so, check that link.
1970 C-10 lwb, 307 V8, THM-400 1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver) |
I have had this happen to me before. I would put money on the fusible link being bad
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
That's not a ground wire, it's a fusible link if it comes off the positive post of the battery. You can replace them but first check that there is no short to ground on the wire that comes off the junction block on the fender.
It's the one on the left.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Disconnect the two battery cables clean the contacts and hookup the two wires to see if that was the problem
It was the fusible link. Thank yall for the help. I am late for work, but oh well I get a long weekend now. lol
Mine wasn't visible it was hidden behind the battery. |
