04-06-2015, 12:10 PM | #1 |
intermediate shaft questions
A question for the experts? On 69 -72 trucks with factory tilt power steering, the intermediate steering shaft is installed with a preload spring and large washer at the connection between the column and the intermediate shaft. I have noticed that some install an after market shaft without this preload spring and washer. Does this create any issues with the operation of the steering column or shifting.
Thanks in advance |
04-06-2015, 01:53 PM | #2 |
Re: intermediate shaft questions
GM didn't spend money on things it didn't need to. Unless the aftermarket ones somehow obviate the need for it, it should be there -and- be properly adjusted per the shop manual.
These trucks aren't made of billet, gotta have slack between the frame and your hands somewhere!
04-06-2015, 02:01 PM | #3 |
The Older Generation
On the columns that have them, the spring and washer hold the lower steering column bearing in place and the spring applies the preload to the lower bearing, hence the name. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-07-2015 at 12:40 AM. |
04-06-2015, 02:50 PM | #4 |
member #16
You mention factory tilt power steering, if that is the case then the factory tilts had a lower brg retainer and did not use the spring and washer.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-06-2015, 05:35 PM | #5 |
No need for the spring and washer on tilt columns
04-06-2015, 05:43 PM | #6 |
As always, everyone here is a great help. Thanks so much for the info.
04-06-2015, 05:56 PM | #7 | |
Always on the hunt...
04-06-2015, 06:04 PM | #8 |
Mel. Thanks again for the info. Great help!
