Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 04-08-2015, 09:29 PM   #1
engineer_gregh
engineer_gregh's Avatar
6.2L Advice
Folks if anyone has experience with the 6.2L I would appreciate advice. Its a 2011 GMC Yukon Denali I bought new. I posted the thread to the 07+ board but I thought I would open it up to a wider audience. http://67-72chevytrucks.com/vboard/s...d.php?t=665845
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 04-09-2015, 07:18 AM   #2
Re: 6.2L Advice
I am here in this section because I know about 67-72 GM Trucks. I thought this might be a question on the 6.2L diesel some people swap, which I also have a lot of experience/knowledge on. They went and reused this engine displacement for a gas motor. I'll have to watch out for that now. Never had anything newer than '95 and know about nothing about anything so new. I buy stuff that new so I don't have to work on it
Old 04-09-2015, 08:32 AM   #3
russgoodman
russgoodman's Avatar
Re: 6.2L Advice
I just rolled 48,000 on my 2008. I've never noticed the piston slap on mine. My buddy had a 2007 he bought and he had it. Not really sure what they did to fix it. I will ask if he remembers.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 04-09-2015, 11:35 AM   #4
BrianG
BrianG's Avatar
Re: 6.2L Advice
My 5.3 has had the piston slap issue for well over the last 100,000 miles. With 175,000 on it now, I don't even worry about it. It's just something they do. So, hopefully its not a big deal for the 6.2 either.
BrianG is offline   Reply With Quote
Old 04-09-2015, 11:56 AM   #5
hugger6933
Re: 6.2L Advice
The main problem with that model is the lifter retainers breaking causing lifters to rotate in the lifter bore. Good for HYD lifters bad for rollers. Jim
hugger6933 is offline   Reply With Quote
Old 04-09-2015, 02:16 PM   #6
Aruba1
Re: 6.2L Advice
I don't think he is referring to the 6.2L diesel engine, I believe he is talking about the L92 6.2L LS3 style that is in his Denali.
Aruba1 is offline   Reply With Quote
Old 04-09-2015, 08:56 PM   #7
clinebarger
Re: 6.2L Advice
The oil pump pressure regulator valve could be stuck open, I have seen this once before on a 408 (Stroked 6.0L). This is the only oil pump failure I have seen on any LS engine. Gerotor pumps are virtually bulletproof.
Like you, I worry about the dry starts/runs this engine has seen.
The VVT/AFM LS engines have been a problem from the start, Oil consumption, Lifter failures, Timing chain tensioner failures (Causing bent pushrods) & AFM manifold screen clogging.
If you were to install a new engine, Buy a 2008 & up LS3 long block, All your accessories, Intake, Oil pan, & exhaust manifolds will bolt right on. The only thing that has to be done is some tuning to get rid of the VVT/AFM.
Speartech.com or PCMforless.com can handle a mail order tune.
A new GM LS3 long block runs $5047.97 (+$1200 core), Your L92 is a suitable core, $1000 to install, $300 for fluids/Gaskets/misc. $250 for a mail order tune.
Enjoy another 200,000 miles worry free.
clinebarger is offline   Reply With Quote
Old 04-11-2015, 07:47 AM   #8
engineer_gregh
Re: 6.2L Advice
Update. Dealer installed new oil pump, sensor, and o-ring. Pressure still goes to almost zero after engine is warmed. Mechanical gauge shows the same as the cluster gauge. Dealer committed to finding the cause even if it means disassembly of the engine at no additional cost. I saw the engine with the oil pan off, clean as a new engine internally, and tech states there was absolutely no metal in the pan or screen when removed. I don't know enough about the modern engines to make an educated guess as to root cause or next steps. I'll up date the thread as I find out more. I appreciate all the input and advice from everyone.
Greg Smyrna TN
