Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 04-08-2015, 11:45 PM   #1
Blazerowner
Blazerowner's Avatar
2005 Corvette LS2
2005 Corvette LS2 with 15k Miles. I bought this out of a friends 69 Chevelle that was wrecked only 700 miles after the swap. The wiring is a standalone harness modified by Speartech with a base tune ECU. It has hookups to run an auto. It will comes with the dbw Pedal which has been modified to be straight down instead of offset. It has a Kwik Performance alternator/power steering re-locating bracket to clear the steering box and I believe a CTSV pan. I can confirm this. I am only selling to buy an LSX 454.
Pretty much everything you need to get up a running.
Its a nice motor and I have been on the fence as it's a low mile engine and I knew the seller. He spared no expense on the swap.
Asking $6500.
Shipping can be arranged and I think domain is usually a good choice. I had a t56 shipped to me through FEDEX a few months ago.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 04-09-2015, 08:06 AM   #2
solidaxel
solidaxel's Avatar
Re: 2005 Corvette LS2
Has the engine been "opened" Intake, oil pan heads?
How long has it been setting?
Which power steering pump does the engine have?
Is there a A/C pump and brackets?
Are there exhaust manifolds?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-09-2015, 11:56 AM   #3
Blazerowner
No exhaust manifolds the rest is stock I believe. My friend didn't have air hooked up but the power steering was hooked up to the stock steering box. No manifolds it had headers. Yes it has an ac pump but in the stock position. It's been sitting about a year now but all openings have been covered by tape. Nothing has ever been removed I didn't see the point considering the low mileage. it ran good when pulled and the car was totaled in the rear so no engine damage.
Kirk
66 Nova
Old 04-10-2015, 10:31 AM   #4
solidaxel
solidaxel's Avatar
I would like to see some better pics of the mounting brackets on the drivers side
LS 3 4L70E
Old 04-10-2015, 08:59 PM   #5
Blazerowner
The kwik bracket? I can take some more later.
Kirk
66 Nova
Old 04-11-2015, 12:09 PM   #6
Blazerowner
Here's some more
Kirk
66 Nova
Old 04-11-2015, 01:32 PM   #7
solidaxel
solidaxel's Avatar
What do you think shipping will cost to 85701?
LS 3 4L70E
Old 04-11-2015, 01:34 PM   #8
solidaxel
solidaxel's Avatar
Is there a flywheel and pilot bearing or a flex plate on the engine?
LS 3 4L70E
Old 04-11-2015, 05:07 PM   #9
Blazerowner
No I have a t56 magnum and it came with a clutch so I didn't buy the flywheel when he sold it to me. I'll try to get a shipping quote as soon as I can.
Kirk
66 Nova
Old 04-11-2015, 05:46 PM   #10
Blazerowner
I ran a couple of quick quotes and I am unsure on the class. It says 150 on FedEx which gives me a quote of over 1000. Its 950 on old domain with that class. Seems rather high to me. I will call and try to get a more accurate quote. I would think 5 or 600 is what it should be.
Kirk
66 Nova
Old 04-11-2015, 05:56 PM   #11
Blazerowner
I did a little research and an engine should have a freight class of 85. Old Domain says 588 for that class and FedEx says 699. Sounds about right. I can get a pallet and build a crate around it to protect it.
Kirk
66 Nova
Old 04-12-2015, 06:56 PM   #12
Blazerowner
I'll be in Los angeles on the 22-23. I could bring it and we could meet up if you want to save on shipping.
Kirk
66 Nova
Old 04-20-2015, 10:03 AM   #13
solidaxel
solidaxel's Avatar
Thanks, found a local engine and trans
LS 3 4L70E
Old 04-20-2015, 11:21 PM   #14
Blazerowner
No problem. Thinking I might keep it since most people have lowballed me on it.
Kirk
66 Nova
Old 04-23-2015, 01:50 AM   #15
el chile verde
Just My opinion but if you really think about it you can purchase than ls3 with trans harness and computer, for less that what your asking for just the engine. So maybe the offer your getting aren't that bad.
el chile verde is offline   Reply With Quote
Old 04-23-2015, 09:51 AM   #16
solidaxel
solidaxel's Avatar
Where are you looking for your LS 3 trans and computer?
LS 3 4L70E
Old 04-25-2015, 03:50 AM   #17
Blazerowner
You can't purchase an ls3 with trans controller harness and computer for less than I'm asking even used. The ls3 alone is around 6500 for the 430hp version with no harness. I have the trans harness and computer with it as well which is included. It's a good price considering what higher mileage engines are running on eBay. I'm not asking 6500 for just the engine. The stand alone harness, computer which is tuned by Speartech, pedal, and all the accessories are included. Easily a couple thousand in parts. The highest offer I have had is 3500 which is a joke. No real offer has been thrown out so it is what it is.
Kirk
66 Nova
Old 04-27-2015, 03:37 AM   #18
el chile verde
Look them up on this site car-part.com. You can get a complete change over ls3 ,just like I said , harness computer, trans, accessories. And I can assure you if they have one and they are located near you, if you take cash they'll give you an even better deal, than what they have it listed for , money talks.
Old 04-27-2015, 08:55 PM   #19
Blazerowner
There is no where out there selling all that for under 6500. Ls3s are on eBay for more than 6 with a harness and that's used. They run well above that with the tranny unless you're talking about a truck engine which is not the same engine. Furthermore, my engine is practically new when the engines I see have much higher mileage. How much is a rebuild and new parts? Even Ls1s with lower mileage are in the 4s and 5s. I'll keep my ad at that price if someone wants to have a clean ls2 for a good price then I will get it. If not I have plenty of projects to put it in. I understand if you don't like my price that's why you make an offer, but I think you are looking to bash rather than you are actually looking for an engine. If you can get an engine cheaper by all means buy it.
Here's my sources not hearsay.
http://m.ebay.com/sch/i.html?_nkw=ls...0.Xls2&sqp=ls2
http://m.ebay.com/sch/i.html?_nkw=ls...sqp=ls3+engine
Kirk
66 Nova
Old 05-09-2015, 07:35 PM   #20
Blazerowner
Update:
Price is 5500 firm.
Kirk
66 Nova
Old 06-19-2015, 12:45 AM   #21
TxOutCast
Kirk do you still have this engine and all the accessories?
TxOutCast is offline   Reply With Quote
Old 06-21-2015, 11:13 PM   #22
Blazerowner
Yes I still have it.
Kirk
66 Nova
