04-10-2015, 01:13 PM | #1 |
Thunderbird IRS in an AD Truck
I am still in the planning stages for this project, but I figured I might as well document all the info I am digging up!!
I know this has been done before, but I could find very little documented in regards to a Chevy install. ol' chebby over at Classic Parts Forum has one in his 3600 and I have spoke with him numerous time about it. Below is his truck....and another truck he built. Good donors are 1989- 1997 Thunderbird/ Cougars and 1993 - 1998 Lincoln Mark 8. The Fords were on coil springs, the Lincolns are all on bags. Fords are available in 7.5" and 8.8" with drums and discs available. The Lincolns were 8.8 only, and only disc brakes. Depending on your location, they can be bought pretty cheap. I found a 8.8" in 3.23 ratio with discs locally for $250.00. My plan is to put it on air. With this set up, you can lay frame without a huge notch, or relocating the height of the bed floor. Below is a picture of the IRS in a TF truck. more later.......... |
04-10-2015, 01:46 PM | #2 |
Re: Thunderbird IFS in an AD Truck
A few more pictures of them installed.
Ol' Chebby's 3600. Ford Install Team 321 makes mounting brackets for the Ford IRS system to mount to Ford trucks. A link to their website is below. Dave at Team 321 is a great resource for IRS info. http://team321.com/truckirs/truckirs.html Below is a picture of a 56 Ford installed with the Team 321 kit. Another Ford Install |
04-10-2015, 01:52 PM | #3 |
Below is a great build thread on step by step install in a 1951 F1
http://www.ford-trucks.com/forums/81...ll-how-to.html |
04-10-2015, 01:58 PM | #4 |
I had looked into that once because I have one those rear ends. My plan was to leave it as a bolt in unit. But didn't when I became disillusioned with the Danforth kit and went to the dakota chassis.
http://67-72chevytrucks.com/vboard/s...d.php?t=414646 |
04-10-2015, 02:09 PM | #5 |
I have my heels dug in on staying with the stock frame, so I really like this option.
04-10-2015, 03:30 PM | #6 |
Not sure if titles can be modified, but looks like all Rear installs instead of ifs right? Or are you going to do the front as well?
04-10-2015, 03:41 PM | #7 | |
Thanks for the heads up. I have not decided on IFS yet. |
04-10-2015, 05:20 PM | #8 |
Had I kept the stock frame I would have used the T-bird rear. The dakota was sitting there, my son quit driving it.
04-10-2015, 07:38 PM | #9 |
That looks interesting and you had me wondering with that Thunderbird IFS in that I was trying to figure out what you were going to do with the struts.
04-11-2015, 01:01 PM | #10 |
Re: Thunderbird IRS in an AD Truck
Obstacles:
Rear end bolt pattern is 5 x 4-1/4. New hubs can be bought for 5 x 4-1/2 which would allow a much better wheel selection. Redrilling the stud holes is also an option. I am hoping there is enough room to redrill them 5 x 4-3/4 so I can keep my existing wheels. I won't be able to determine that until I pick up the rear end. |
04-11-2015, 01:21 PM | #11 |
My neighbor just finished a 52 Chevy AD truck and he installed a 300 ZX IRS and it fits great and rides great the bolt pattern is a 4 1/2 Ford, this is the only pic I have.
There is a rod builder in Washington that is all he uses is 300 ZX Just as a thought, have you heard about these?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-11-2015, 01:24 PM | #12 |
Found another one !
04-11-2015, 02:50 PM | #13 |
Awesome truck. I have heard of the 300z IRS....but have never seen one installed.
04-11-2015, 03:00 PM | #14 |
Wonder why ford did that? Figure it would have been cheaper to have everything 5 x 4.5...
04-11-2015, 03:03 PM | #15 |
Very good question.
04-11-2015, 03:12 PM | #16 |
LOL...cuz its ford...
I've owned a few in the day and I have caught myself asking myself, usually when under the hood, "why'd they do that? What where they thinking..." |
04-11-2015, 04:45 PM | #17 | |
I spoke with two people regarding re drilling the hubs 5 x 4-3/4". One person said it is not possible....the other said it is. I guess I will take the hubs to a local machinist and ask. |
04-12-2015, 12:48 PM | #18 |
I looked at some in the junkyard. With a quick look and a tape measure, I didn't think there was a big enough flange to re-drill to 4-3/4". I know that a lot of people have successfully re-drilled to 4-1/2". Some people buy the cobra 4-1/2" hubs to swap. But, they are expensive. I think there are a lot more wheel choices in 4-1/2" vs. 4-3/4", especially positive offset that you will need with the wide rear end.
04-12-2015, 01:32 PM | #19 | |
Cragar wheels like I am running now are available on 4-1/2". Just need to figure out what offset I will need. I think this rear end is 63" wide. |
04-12-2015, 07:10 PM | #20 |
04-14-2015, 10:46 AM | #21 |
That is good to know!!
04-14-2015, 05:47 PM | #22 |
04-14-2015, 06:42 PM | #23 | |
04-14-2015, 09:51 PM | #24 |
Your welcome!!
12-11-2015, 05:11 PM | #25 |
Any updates? been a while.
Bill |
