Old 04-11-2015, 09:08 PM   #1
sgt1022
fuel problem
I have a 71 c10 w/350ci edelbrock carb Holley 110 gph blue pump through regulator at 4 psi. With braided-6 line. After I drive for an hour or so in traffic my regulator starts dropping pressure when I'm at idle. The problem has left me stranded twice. I can loosen a fitting and in a couple seconds fuel starts flowing again and truck starts immediately. My fuel lines are a fair distance away from exhaust heat. I do not have a return line.
sgt1022 is offline   Reply With Quote
Old 04-11-2015, 09:31 PM   #2
MagmaJct
MagmaJct's Avatar
Re: fuel problem
Funny. I have a 71 C10 w/350 and Carter AFB (Edelbrock.) However I'm running the stock pump set up.
I wonder what kind of suction that pump's pulling. If you have the wrong gas cap, or if the evaporative emission control system has been deleted, with time, as the fuel level is drawn down in the tank, a vacuum can form. (Like trying to drink from a Coke bottle without letting air in!)
You could loosen the gas cap when this happens and see if it helps.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 04-12-2015, 09:41 AM   #3
sgt1022
Re: fuel problem
I will try it. IT really only happens only after driving in stop and go traffic or during the daytime hours that's why I think heat is playing a factor.
when I'm on the highway it'll run 4 psi all day long without hesitation.
I feel the pump is heating up cause it slowly cuts out in traffic and takes about 30 sec. to kick in after starting during these times.
Old 04-12-2015, 09:44 AM   #4
sgt1022
Re: fuel problem
The only thing on the EEC that was deleted is the canister. That was gone when I purchased the truck. All the lines are there and when I replaced the tank I hooked it back up the same way.
Old 04-12-2015, 11:09 AM   #5
cdowns
cdowns's Avatar
Re: fuel problem
do you hear a pressure rush when you remove the gas cap?? if yes you aint got it hooked up right
Old 04-12-2015, 11:39 AM   #6
MagmaJct
MagmaJct's Avatar
Re: fuel problem
Okay, now we're making progress. The line, that used to go to the canister, where is it now? Is it open to atmosphere? Is it plugged?
The original gas cap is a "vacuum/pressure" cap according to textbooks. By that very short description, I can only assume it's essentially a check valve type venting. That is, it allows air in to prevent a vacuum, yet doesn't allow vapors out. (Since vapors would then vent to the atmosphere, no the canister.)
Old 04-12-2015, 12:16 PM   #7
sgt1022
Re: fuel problem
No pressure release when removing gas cap.
The line is open to to atmosphere
Old 04-12-2015, 10:42 PM   #8
rotten67
Re: fuel problem
Where is the pump located? Needs to be as close to tank as possible. Even better if it's in the tank. It's easier for fuel to vapor lock under vacuum than pressure.
rotten67 is offline   Reply With Quote
Old 04-12-2015, 10:47 PM   #9
sgt1022
Re: fuel problem
Pump is within 12-14of tank
