Wiper motor, CALLING DOCLOC...
Symptom, (2 speed unit)
Runs low speed in both positions and nothing from the washer when depressed... A list of what I've checked with old motor and switch still in truck: Wires hooked properly to both switch and motor Removed switch and cleaned connections Jumped light blue and black wire at harness and grounded them ![]() Still one slow speed and no washer, so could we say the switch is good and the motor is bad? I've done a lot of search reading and just want to confirm or get other ideas before spending...thanks ed ![]() |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Wiper motor, CALLING DOCLOC...
sub'd: same issue in my K5 with a single, slow speed. I pulled a used wiper motor figuring that's the issue. Not eager to tear into my dash yet again if that can be avoided.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
The Older Generation
I haven't run into this problem before but I think there are really only a few things that can cause this. Bad motor, bad switch, bad ground, or binding wiper arm transmissions. I guess the ground would be the easiest thing to try first. Get a jumper wire with alligator clips on both ends. Connect one end to a good ground on the dash and connect the other end to bare metal on the wiper motor. (NOT one of the mounting bolts) If that doesn't make any difference move the wiper arms up and down (gently) and see if the linkage under the cowl vent is moving freely. It won't move far but you should be able to tell if the linkage or wiper transmissions are binding. If there isn't any problem there and there aren't any broken wires on the connectors, try replacing the switch. If that doesn't help I guess it would have to be the motor. As far as the washers, they are almost a lost cause. You can buy rebuild kits but it is a crap shoot whether they will work after a rebuild, or for how long..... If anyone else has any Ideas feel free to chime in.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-12-2015 at 09:53 PM. |
![]() Join Date: Jan 2013
Happened to me recently. New motor did not fix it, ended up replacing the switch itself and the motor works right now. I have the two speed as well. I didn't bother with the washer pump, so I can't say if that was why the pump didn't work, but it fixed the motor issue. I figured, is a new pump worth the money? I visit the gas station weekly as it is haha
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
By removing the switch from the wiring harness and grounding the light blue and black wire together with no change in speed, would this not make you think that the switch is still good? I'll definitely try just re-grounding the motor case metal only. Thanks for help ed...
