04-12-2015, 01:23 PM | #1 |
70+ ( Old Skool Club )
Door Lock Question
I just got my truck out of storage on Friday and am enjoying driving her. I cannot lock the passenger door with the key when the door is closed. When the door is open the lock button goes up and down as it should and I hear the lock and unlock mechanisms clicking. Looking at the latches there doesn't seem to be any adjustments ( unless the door needs adjusting ) to the latches on the door and striker on the jamb. Would lubing the striker and latch on the door cure my problem?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-12-2015, 01:39 PM | #2 |
Carpe manana
Re: Door Lock Question
Greg try pushing the door in a little bit then turning the key to lock it. If that works chances are the latch is worn.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
04-12-2015, 02:00 PM | #3 |
Thanks Pete, you mean the latch on the door?
04-12-2015, 02:26 PM | #4 |
Yes....
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-12-2015, 02:26 PM | #5 |
Went and did that and you were right. The door locks when I pushed on it and unlocks with key. Thanks for the help. I can lock the door until I get a new ( do they reproduce them ) latch.
04-12-2015, 09:19 PM | #6 | |
The Older Generation
Also roll the window down and spray some penetrating oil on the back of the lock and on the latch. You can see down in there pretty good through the opening with the window down. (if you use a good light) LockDoc
04-12-2015, 11:14 PM | #7 | |
04-13-2015, 08:49 AM | #8 |
Carpe manana
You can buy new but finish resembles cadmium rather than phosphate coated as the original. I've seen a member have new examples phosphate coated and they turned out nice. Try a good used piece.
04-13-2015, 11:11 AM | #9 |
I think I will try Leons suggestion first and if that doesn't work can probably live with giving the door a little shove in order to lock it. I'd rather get a good used one rather than use a new one that doesn't look original.
