Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 04-13-2015, 08:19 PM   #1
68panelman
68panelman's Avatar
Aluminum wheel cleaner for engine block&heads
Is there anything to spray on late model aluminum engines that have that white powder look?, Would wheel cleaner work and then a spray of lube?
68panelman is offline   Reply With Quote
Old 05-21-2015, 06:15 AM   #2
eager_adventurer
Re: Aluminum wheel cleaner for engine block&heads
I use Meguiar's G14324 Hot Rims Aluminum Wheel Cleaner. I order it from Amazon.
eager_adventurer is offline   Reply With Quote
Old 05-30-2015, 04:38 PM   #3
thzpcs
Any uncoated aluminum cleaner should work quite well.
thzpcs is offline   Reply With Quote
Old 05-30-2015, 05:23 PM   #4
68panelman
68panelman's Avatar
OK, I'll try that. Any coatings to apply after clean an dry? Thanks guys
Old 06-17-2015, 02:08 PM   #5
Willie Makeit
Willie Makeit's Avatar
I can't recommend this stuff enough for use on bare cast aluminum. Amongst my car buddies, we like to call it "magic juice" and we use it on everything from aluminum heads, blocks, intakes, timing covers and anything else that needs a good scrubbing. Spray it on and let it sit for a few minutes then scrub with a brass brush or red scotchbrite pad. It is acidic so latex gloves are a plus.
O'Reilly's and Advance Auto carries it in my neck of the woods for about $7 a spray bottle.
Funny thing is I've never tried it on a set of wheels.
Amazon.com: Eagle One Etching Mag Wheel Cleaner... Amazon.com: Eagle One Etching Mag Wheel Cleaner...
Willie Makeit is offline   Reply With Quote
Old 06-22-2015, 01:25 PM   #6
1963c-10
1963c-10's Avatar
Amazon.com: Eagle One Etching Mag Wheel Cleaner (23 oz.): Automotive
How does it react with painted parts like engine blocks? I'd like to try this on my intake.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-23-2015, 08:13 AM   #7
Willie Makeit
Ive never tried it on painted parts so I can't say.
Old 06-23-2015, 02:26 PM   #8
68panelman
68panelman's Avatar
I assume it would be fine if you spray carefully and wash it out liberally
Old 06-25-2015, 09:33 AM   #9
1963c-10
1963c-10's Avatar
Thanks. I'd like to clean up the intake, but don't want to destroy my block paint in the process.
Old 06-26-2015, 10:43 AM   #10
thzpcs
I think it'll be fine as long as you rinse it off quickly.
Old 06-26-2015, 10:32 PM   #11
Willie Makeit
I agree but would be cautious to not spray it directly on painted parts. try it on the aluminum parts only.
Old 06-28-2015, 01:29 AM   #12
esbstuff
I use A to Z wheel cleaner with great results.
esbstuff is offline   Reply With Quote
