04-14-2015, 09:59 AM | #1 |
What to be done for stripped/frozen door panel screws?
I am in the process of replacing the door panels for my little truck. 2 of the pressed in nuts for the door panel screws, which are technically bolts, have dropped out of the door.
Are there cage nuts that I could put in? I don't weld, (it is on my bucket list) so I can't put square nuts behind and tack in place. What would be an easy effective, way to proceed please?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-14-2015, 11:09 AM | #2 |
I am a Referee of life.
Re: What to be done for stripped/frozen door panel screws?
IIRC I used cage nuts. It's been a while since I had the panels off but I haven't had any problem. I think I used ones that clip over the edge and reach the hole.Hope this helps. They may be J nuts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-14-2015, 11:50 AM | #3 |
member #16
Wes at classicheartbeat has the caged nuts.
http://www.classicheartbeat.com/nuts_&_bolts1.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-14-2015, 02:49 PM | #4 |
thanks guys. I figured it would be something like that. I do have the screws already. I'll bring them to the Ace store and get the capture nuts.
04-14-2015, 06:38 PM | #5 |
Plastic license plate clips the kind that snap into the bumper, will do well in a pinch for those metal little suckers. That would be the 99 cent solution, but they are probably a couple bucks now. I don't look to often at prices of stuff by the time I need it I need it.
04-14-2015, 09:51 PM | #6 | |
The Older Generation
This is what I used for mine.... LockDoc
