04-16-2015, 02:34 PM | #1 |
underbed tanks and carbureted engines...
Are any of you running an underbed tank with a carbureted motor? If so does the mechanical pump have enough umph to pull the fuel all the way from the rear or do I need to install an electric pump to take up the slack?
Thanks in advance, Mike
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
04-16-2015, 03:06 PM | #2 |
Re: underbed tanks and carbureted engines...
Why wouldnt it? Look at the old land yacht cars from the day....
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
04-16-2015, 03:15 PM | #3 |
Stalker Nate
My '64 Caddy was mechanical & gas tank 18' away haha They can pull it on a truck just fine. You can run electric though if wanted or needed.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
04-16-2015, 03:32 PM | #4 |
Prestige Worldwide
My Suburban does....
04-16-2015, 04:27 PM | #5 |
There's no reason a stock mechanical pump wouldn't work with an under bed tank. I've had bad luck with electric pumps, and would recommend using a mechanical pump for durability.
I can't remember the last time a car of mine quit and the problem wasn't the electric fuel pump... |
04-16-2015, 05:05 PM | #6 |
As everyone else has stated, MANY 50's cars up through introduction of electric fuel pumps have a fuel tank in the rear and a mechanical fuel pump and they're still kickin'!
04-16-2015, 05:08 PM | #7 |
Its a Truck Thing......
The same model Panel and Suburbans use the same pump as the trucks. I have moved my tank to the back oon my SWB and no issues.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-16-2015, 05:21 PM | #8 |
All about them K’s
These trucks had optional factory under bed aux tanks when new...of course it will work
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-16-2015, 09:49 PM | #9 |
Just installed my new Boyd tank, all I did was hooked my hand vacuum pump and pulled fuel up to the fuel pump. Fired right up and works fine. 250 six cylinder with mechanical fuel pump. I ran 3/8" brake line for fuel line and reduced it down to 5/16" to the pump.
1970 C10 SWB |
04-16-2015, 10:58 PM | #10 |
All Blazers and Suburbans were set up that way. No problem getting gas up to the pump.
04-17-2015, 02:14 PM | #11 |
I am running under bed aluminum fuel cell with Holley carb and Holley mechanical fuel pump. No problems whatsoever.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
