04-16-2015, 04:19 PM | #1 |
Need some help. WTHIT?
What the h... is that? By "that" I mean the the 2 holes and plugs in this firewall just to the left of the heater core cover. Both look improvised and one looks like a cork. Really. Any help would be appreciated.
And for the title of this thread, I used this old SNL skit for inspiration. https://www.youtube.com/watch?v=RV7Qz640OeM Thanks, Phil |
04-16-2015, 04:24 PM | #2 |
Re: Need some help. WTHIT?
Really hard to see on my phone, but I'll guess they're plugs for an old aftermarket a/c.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
04-16-2015, 04:36 PM | #3 |
These are your heater core hook ups for the heater inside. The heater core may be bad and they've just plugged it off...
04-16-2015, 05:10 PM | #4 |
Those are definitely part of a PO hack job, possibly to install an add-on A/C system. Either way, that cork is one way to plug a hole!
04-16-2015, 05:22 PM | #5 |
Former underdash A/C hose holes, very common.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-16-2015, 06:28 PM | #6 |
my truck has these holes (not plugged) and never had a/c?
04-16-2015, 06:37 PM | #7 |
Old member
Those are where the factory heater hoses would go on a factory AC truck. If they are not being used then I would get them out and plug up the fire wall. A dealer add on AC would explain them also.
04-17-2015, 11:12 AM | #8 |
Thanks guys. As always, this forum has the answers. I'll work on upgrading the cork.
Phil |
