04-19-2015, 07:36 PM | #1 |
67 suspension drop
I have a factory truck. 6 lug , drum all the way. Wanting to do a 5/7 or 4/6 drop and disc conversion all the way. Any suggestions ??
04-22-2015, 01:29 PM | #2 |
Re: 67 suspension drop
I got mine from CPP www.classicperform.com got 4wheel dick brake, 4 inch lower springs, new trailing arm support, (corrects the pinion aliment) 2 inch dropped spindles and 2 inch lowering springs, sway bars front and rear, and now adding tubular A arms. maybe 3 grand for all
04-22-2015, 02:00 PM | #3 |
67-72 parts collector,…
04-22-2015, 02:44 PM | #4 |
Thanks for the info . Ready to get started !!!
04-22-2015, 03:02 PM | #5 |
There is a less expensive way to go for the front brakes.
I recommend that you use the stock disk set up off of a 71-72 1/2 ton, (If you get the 72 make sure you get the front suspension crossmember) and grab the power master cylinder/booster brackets, and pedal push rod. Grab a 71-72 rear axle. For the rest of it go CPP all the way. Get their 2"/4" drop springs, 2" modular drop spindles and disk brake bracket, 2" lowering blocks for the rear axle, Rear shock relocation kit, 4"/6" Drop shocks, Front shock reinforcement kit, Rear Disk w/e-brake kit and Rear sway bar. It will handle and stop like a Camaro instead of a pickup. Last edited by Xeen; 04-22-2015 at 03:08 PM. |
04-22-2015, 03:23 PM | #6 |
Brian , great pics , great looking build. I've been looking for donor trucks but found that they are few and far between around here or way over priced for parts. Gonna keep looking.
04-22-2015, 03:24 PM | #7 |
what kind of brakes
04-22-2015, 03:26 PM | #8 |
Oh by the way. First forum I have joined so bare with me on trying to figure out how to use it.
04-22-2015, 03:28 PM | #9 |
At the moment none. Just want to convert to disc on both ends.
04-22-2015, 03:29 PM | #10 |
Work calls. Check in later. Thanks to all.
04-23-2015, 10:58 AM | #11 |
I went pretty conservative with the suspension on mine and only did a 1/3 drop. I really regret it. I like the way the 4/6 drop looks. If I had to redo it (and I may one day), I would go the route that Xeen describes. Good luck with your build!
