04-20-2015, 06:21 PM | #1 |
C10 addict
Billet Aluminum Deluxe CST Dash Knobs
UPDATE:
After several iterations these are finally a reality I'll try to get some install pics this weekend. The price will be $12 a piece for lights, wiper, choke, throttle and radio knobs. The choke and throttle knobs thread on just like the factory, the wiper and radio knobs have a set screw and are a very tight fit. The headlight knob has a set screw as well (it uses the same knob as the throttle and choke so there are threads inside) and it also is a very tight fit. You have to remove your old knob off of the factory shaft. I've put a lot of time and thought into these to make sure every knob fits well with no slop. For the cigarette lighter I have two options, I can provide the knob with the lighter element which fits the 67-72 lighter socket but doesn't fit as tight as the original so if you actually use the lighter this isn't a good option since it could pop completely out when it gets hot. If you don't light things with the lighter this should be fine. The other option is a complete replacement element and socket. The replacement sockets have a spade connector so you would need to splice a spade onto your wiring or swap over the connector piece from your original socket. This is a good option if your socket is old and/or doesn't work. The cigarette lighter price will be $12 +$5 for just the element or +$8 for the element and socket Shipping will be $4.50 for six or $7 for as many as I can fit in a Priority Mail flat rate box
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 07-11-2015 at 04:39 PM. |
04-20-2015, 06:40 PM | #2 |
70+ ( Old Skool Club )
Re: Billet Aluminum Deluxe Dash Knobs
I really like your ideas Jared. I'd like to what a set of 5 looks like on a truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-20-2015, 07:53 PM | #4 |
C/10 junkie
Interested
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
04-20-2015, 09:41 PM | #5 |
Interested. Would also like to see some pics of them on a dash. Thanks.
04-20-2015, 09:54 PM | #6 |
Interested in a set of 3
04-20-2015, 09:56 PM | #7 |
5 sounds good
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
04-20-2015, 10:06 PM | #8 |
How 'bout a choke knob? (Yes, I know, it's threaded....)
04-20-2015, 10:07 PM | #9 |
I would be in a set of five
04-20-2015, 10:53 PM | #10 |
would be interested in a couple of sets
Thanks - Chad
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
04-20-2015, 11:09 PM | #11 |
Loves all GMC trucks
I'm in for a set of each!
Mike If your helping someone and expecting something in return... your doing business not kindness! |
04-20-2015, 11:37 PM | #12 |
I would take 3
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-21-2015, 09:08 AM | #13 |
I would be in for a set for a 67 to include the choke.
Thank so much, Jake |
04-21-2015, 09:58 AM | #14 |
Roto Reuter thats the name...
I like it Jared. I'd be in for the set of 3.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
04-21-2015, 10:42 AM | #15 |
C10 addict
Sounds like there is enough interest to order them, thanks for all the feedback! The 67 choke will be the same as the headlight knob with a set screw. It would cost a lot more to create a third version for a limited few that need a threaded version.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
04-23-2015, 09:38 PM | #16 |
Great idea! I would take a set of 5.
04-23-2015, 09:56 PM | #17 |
I would take atleast 1 set of 3 + choke
Trey Oney |
04-23-2015, 11:00 PM | #18 |
I will take a set of 3.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
04-23-2015, 11:14 PM | #19 |
04-24-2015, 09:23 AM | #20 |
I'd like a set of 3
04-24-2015, 10:48 AM | #21 |
Id like a set of 3
04-24-2015, 03:28 PM | #22 |
intrested in a set of 5
Scotts72C10 |
04-24-2015, 03:29 PM | #23 |
I would like to get a set of 3 if you make some.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
04-24-2015, 08:28 PM | #24 |
I would be in for a set of 7 (headlight, wiper, Choke, Throttle, cigarette lighter, and both radio knobs)
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
07-07-2015, 03:10 PM | #25 |
C10 addict
I'll try to get some install pics this weekend. The price will be $12 a piece for lights, wiper, choke, throttle and radio knobs. For the cigarette lighter I have two options, I can provide the knob with the lighter element which fits the 67-72 lighter socket but doesn't fit as tight as the original so if you actually use the lighter this isn't a good option since it could pop completely out when it gets hot. If you don't light things with the lighter this should be fine. The other option is a complete replacement element and socket. The replacement sockets have a spade connector so you would need to splice a spade onto your wiring or swap over the connector piece from your original socket. This is a good option if your socket is old and/or doesn't work. The cigarette lighter price will be $12 +$5 for just the element or +$8 for the element and socket
