a few questions about blazers
I am looking at a 1972 blazer in carrollton ohio. I was talking to the guy and he said the spid is gone, but it has/had ac, and it was a military edition. I didn't think there was a ilitary edition of the 1st Gen blazers, I thought that was 84-86 cucvs. Am I wrong on thinking this? I am a little bummed that the spid is gone but I would not go all original so it dosent really matter. He said there is a little rust around the windshield, I have heard NIGHTMARES about fixing this. I am new to body work but have a buddy that can help.
http://akroncanton.craigslist.org/cto/4955064610.html it doesn't look like a military blazer, more like a light olive. |
Re: a few questions about blazers
Nope, I'd stay away. Might be a good k5, but not up straight info up front. If your still interested, check into it more.
Oh I will for sure check into it more, it sounds like he doesn't know what he has. I have been searching for a good blazer for over a year and this is the first one even worth looking at. I see you're from Marion, Mi. I am just finding more people around this area.
The ad says it's a month old, I wonder why? Certainly no CUCV in 1972. Check it over real well for rust. Post pictures of any rust and we can tell you what to expect. The black painted under the door has me concerned, could be a mess of bondo that they covered up with that paint.
That could be a great blazer for a great price, but you need to make the blazer prove that it's worth it. Don't go in expecting a $4,000 blazer, go in picking it apart and see if it's worth the money.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#5 | |
I have heard the old trick of the thin magnet on the doors to check for bondo, if it sticks there is very little bondo, if not, there is a lot of bondo. I just asked him if all the hatch hardware is there, if not, most likely no deal. I dont want to search all over eternity for the parts. ![]() |
![]() Join Date: May 2007
I would be way more scared about Ohio rust, than a missing spid!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#7 | |
Would I be shunned if I had a new spid recreated for the finished product? I won't try and sell it as that.(most likely because I won't ever sell it) I was thinking a faux highlander ![]() |
If it has a clean title what's the problem' It is worth what it's worth to you. ?
If you suspect a false title check.. it looks like it has a body lift. If so you should be able to check the frame for a serial stamp number. On mine it is stamped on the top of the frame rail on the driver side frame about center between the back of the drivers door and the rear tire. |
#9 | |
I will check for a frame number, will I be able to match it to the body? Is it just the Vin for the frame? I know it is on the body too. Thank you guys for all of your help! I really mean it. If there is any more things to really look out for, please don't hold back! |
![]() Join Date: Jul 2014
Looks like it has 3/4 ton axles to me. Big yellow Spicer Hubs. It also looks like it had auxiliary fuel tanks at one point. The picture is too blurry to tell for sure. I would make sure the title is clean. The windshield rust would probably scare me away. It can't hurt to go check it out.
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
#11 | |
Yeah the picture is blurry, he said he will try to get more. So check title, windshield frame rust, axles, other rust, anything else not mentioned above? |
#12 | |
I would be very weary and very critical of every square inch, especially underneath looking for rust. Posted via Mobile Device |
#13 | |
Yeah I originally thought it was a 69-70 and he mislabeled it, it was just a clip change. Adding core support and front frame. I didn't even notice the alt on the wrong side. I have an air cleaner that will work. Yeah I am going to take a curved mirror and crawl around and look for rust. |
#14 |
Windshield frame rust isnt too bad to replace...i think a lot easier than rear pillar..rocker box area etc, just measure measure measure. I wouldnt worry about the partial frame vin matching the title but make sure the body tag matches the title. Frame may have been replaced as is one of mine because one of had been a plow truck in the salt belt and they hacked off the front of the frame fit a plow.
#15 |
2wd FTW!!!!
Looks like it has or had auxiliary tanks and if it did they cut out the rocker boxes to put them in. The rocker boxes are your main body support for when the top is off.
#16 |
Carpe manana
![]() ![]() Join Date: Dec 2010
FWIW - the engine or at least heads likely not correct give location of the alternator and may preclude easy addition of the missing AC components. Is that a 3/4t dual diaphragm brake booster?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#17 |
I won't be messing with ac so not much of a worry. I noticed that the alt is on the wrong side, so what chevy engine had the alt on that side? if it is a 3/4 ton brake booster, it is fine by me, as long as it was done properly.
#18 |
I see that, I hope they didn't cut the rocker boxes, but I guess I could fix them if need be. I want to beat up the frame a little too, I will be doing some hauling, nothing too heavy though.
#19 |
69 up cars, and 73 up trucks used the long water pump setup, with alternator on the passenger side.
#20 |
#21 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#22 |
#23 |
Active Member
![]() Join Date: Jun 2013
Man, that's a lot of money for so few pictures.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
#24 |
And bad ones at that...
He said he couldn't get more either, it is an awfully long drive to just go look. I don't want to make 2 trips so I would have to take a trailer, and get 12 mpg. Thee goes 300 in fuel just going there! |
#25 |
He can't get more pictures because it's a rusty pile and he doesn't want you to know it.
See if you can find a board member that is close that will look at it for you.
