Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 05-08-2015, 01:52 AM   #1
joedoh
joedoh's Avatar
parting 1947 GMC 3/4 ton
no cab, interior parts, or sheetmetal.
running 53-54 248 (by casting number) with single barrel carb, good brass radiator. 4 speed granny 1st with reverse lockout and chelsea PTO/hydraulic package, all pto controls included. full open driveshaft, no torque tube. eaton 8 lug rear. dump bed with sides and telescoping 36" single action cylinder. new front tires 235/85/16 on wagon wheels, one new and one used rear tire 235/85/16.5 8 ply on two piece rims. good steering column with later steering wheel in good shape. lever shocks present in front but not hooked up, MIA in rear.
the GMC has a different front crossmember to allow the longer GMC engine to fit. the 248 is high pressure bearings (60 psi oil pressure gauge). still full of oil and coolant. rebuilt delco remy generator not installed.
running boards and mounts have been removed. so has the radiator surround and front bumper/bracket. everything else still there.
tell me what you need and how you plan to get it!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-09-2015, 10:26 PM   #2
joedoh
joedoh's Avatar
Re: parting 1947 GMC 3/4 ton
motor is out, ready for pickup (pun intended)
$150 248 motor complete
$80 radiator
$50 trans
$100 PTO
$50 hydraulic package
$150 telescoping cylinder and brackets
$100 bed, wood sides, and tilt frame. There is at least 80 bucks worth of scrap steel there.
$100 rearend with driveshaft
$150 wheels all 4 or $100 pr.
Old 05-12-2015, 11:17 PM   #3
joedoh
joedoh's Avatar
bed gone
frame gone
rear and front suspension gone.
motor trans and pto setup left.
Old 05-15-2015, 04:56 PM   #4
joedoh
joedoh's Avatar
updated for whats left
$50 trans
