Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-13-2015, 12:48 PM   #1
fitzhume1221
WTB 3/4 ton c20 rear cab mounts
anyone out there have a set of 3/4 ton c20 rear cab mounts with usable rubber?
fitzhume1221 is offline   Reply With Quote
Old 05-13-2015, 09:41 PM   #2
sodly
sodly's Avatar
Re: WTB 3/4 ton c20 rear cab mounts
If you have a pair they can be rebuilt.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 05-13-2015, 09:48 PM   #3
bullwinkle3331
Here is where you could get your existing set re-vulcanized:
http://www.steelerubber.com/cab-moun...ice-70-2212-48
bullwinkle3331 is offline   Reply With Quote
Old 05-13-2015, 09:56 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A lot of guys just convert them to the half ton type mounts.
That's what I did on my 66.
66 C20 Service Truck:
Old 05-14-2015, 09:20 PM   #5
1960chevypanel
What year truck are you working on?
1960chevypanel is offline   Reply With Quote
Old 05-14-2015, 09:40 PM   #6
fitzhume1221
its a 63. heres the deal, the drivers side mount is coming apart and needs to be redone. this is the gf's truck and she practically lives in it as long as the weather permits, so i was hoping to find some usable ones to put on while the originals are being rebuilt(they said a few weeks turn around time). its a pain in the butt, but so is dealing with her if she can't drive her truck for 2-3 weeks!!!
Old 05-14-2015, 10:06 PM   #7
1960chevypanel
Ok I should have them, will check tomorrow
Old 05-14-2015, 11:12 PM   #8
fitzhume1221
sounds good. i won't be around to check the thread til sunday, but if you want, you can text info to 2627166752. thanks!
Old 05-15-2015, 10:35 AM   #9
paulspickupparts
I have a pair of rebuilt 3/4 ton mounts.
paulspickupparts is offline   Reply With Quote
Old 05-17-2015, 06:01 PM   #10
LostMy65
LostMy65's Avatar
Here is another option :
Originally Posted by chevyrestoguy View Post
Had a little time today, so I decided to finish the cab mounts. My C-20, like most, had broken rear cab mounts. I'm usually 100% supportive of anything GM did back in the day, but whoever designed the rear cab mounts on the C-20 and heavier trucks really missed the mark. It's like they are designed to fail. I looked around and found out that you can send your mounts out to Steele Rubber and have then re-vulcanized, but like I said before, I'm not a fan of the design. Tony Smith makes a really nice retrofit kit that utilizes 1/2 ton-style mounts, but I didn't want to spend hardly any money. Brad came up with an idea that fit my plan perfectly. A modification that can be done at home for next to nothing.
As you can see, my mounts were shot:
The first thing to do was to separate the rubber from the mount. A hacksaw or a Sawzall (preferred) works great. Make sure you support the cab before you do this:
Once you get the pieces separated, you have to do the lovely task of getting the rest of the rubber off. The only way to do this is to get your torch and burn it off. Yeah, it's a nasty job, but it's really the only way you can do it. Continue to heat the rubber until it can be scraped off. The remaining rubber can be wisked off with a large wire brush. Get the rubber hot, and then hit it with the brush while it's still molten. The mount has to be clean in order to weld on it, which will come later.
After the "arm" of the mount is removed and cleaned, I placed it back into position and made a measurement of the gap where the rubber block used to reside. It winds up being around 1.5". I determined that the best way to secure the arm and the riveted mount on the frame was to replace the rubber with steel. I wound up going to my local steel yard and bought some scrap steel, 3" wide by 1.5" tall U-channel, .250 thick. I got them for $4 total. I welded the U-channel (flat side out) to the cleaned mount section that's riveted to the frame.
You're probably wondering how I plan to cushion this mount. It's real easy, I bought an Energy Suspension Cab Mount Kit (part# 34137, around $50) for a HALF TON. The bushings that normally attach to the mounts on a half ton will now go into the modified C-20 mount. I took the front mounts and swapped them out (they are the same between the half ton and the three quarter ton). I took the bushings for the aft mount and placed it and the flat washer on top of the mount arm and determined where the arm needed to be located. It's going to sit lower than it was originally, due to the thickness of the bushing. Once I liked where it was positioned, I welded the "arm" to the u-channel. I order to bolt this all together, you have to do a few things. First, the 1/2" x 5" long bolt in the Energy Suspension kit will not work. The nutplate in the cab floor on the C-20s is a 7/16", so you have to go to the bolt shop and get a 7/16" coarse x 5" bolt. Get a Grade 8, it's good insurance. Secondly, the Energy Suspension kit has a steel sleeve that has to insert into the upper and lower bushing. Unfortunately, the attach hole in the C-20 mount is slotted and needs to be enlarged to fit the sleeve. A die grinder works great for this. Once it was all welded and the hole was enlarged, I trimmed off the extra steel for the arm (the curly-Q section) to make it look a little more aesthetic. Here it is all finished (please note that the bolt is not ran down tight in this picture):
No more sagging!!!!
So, all total, I re-bushed all the cab mounts and fixed the problematic aft mounts for $58 (bushing kit, steel, and new 7/16" bolts).
Old 05-24-2015, 01:51 AM   #11
1960chevypanel
Mounts should be there on Tues. Have a great holiday weekend.
Old 05-24-2015, 01:55 AM   #12
1960chevypanel
Found these OG beauties on a '63 in my yard
