Old 05-21-2015, 11:22 AM   #1
jayoldschool
Moderator
Tach wiring help?
I've been looking for inexpensive tach for my truck that would look old. I've found a few Mercruiser tachs that were used on Chevy 6 cylinder engines. Rev range is perfect for a stock 230.
Can anyone tell me how to wire this? Does it just need 12V and coil, or one of the senders?
jayoldschool is offline   Reply With Quote
Old 05-21-2015, 11:57 AM   #2
1963c-10
1963c-10's Avatar
Re: Tach wiring help?
Pink wire to ignition
Gray wire to dash lights
Brown wire to neg - side of coil
Pink wire to pos + side of gauge.
Brown wire to - side of gauge.
In your case it looks like you have a black wire for the light and not grey which would have been factory color.
Also.....HEI or coil?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-21-2015, 12:00 PM   #3
1963c-10
1963c-10's Avatar
Also....great thread here....go to tech articles.....install tach 64-66
http://www.earlyclassic.com/tech.aspx?category=Install Tach 64-66 Chevy3
Old 05-21-2015, 12:02 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The black top wire is for a light is it not?
Red terminal to the + of the coil.
It looks like you would not need a sender unit.
Do you have a Chevy or GMC?
On Chevrolet it went through a grommet along with the windshield washer hoses?
Did I remember correctly?
Old 05-21-2015, 01:42 PM   #5
jayoldschool
Moderator
I have a Chevy 230. Original points.
That black wire at top is coming out of the light housing, for sure.
Old 05-21-2015, 02:14 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
The following link is the closest I can find to your exact tachometer:
http://www.classicglastron.com/phpbb...pic.php?t=7376
Also, blowing the photo up 400% and sharpening the image a bit, it appears there are very faint + and - marks indicating the post orientations in the original 2nd photo:
It also appears this unit was manufactured by AC Delco. There are a few pictures of them on Google Images.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-21-2015, 02:41 PM   #7
jayoldschool
Moderator
Thanks. Great detective work! For 20 bucks, I think I'll give it a shot.
Old 05-21-2015, 03:01 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Correction - I found another similar tach on Images, and it clearly shows the upper center stud being the 12v connection (as does yours). This means one of the lower studs is for ground, and the other is for the signal wire, not 12 volts positive. Unfortunately I can't detect any markings on this other tach even under extreme magnification, so I would suggest doing low voltage testing of the gauge to determine which is the correct post before "going live":
Old 05-21-2015, 06:28 PM   #9
WOLFMANmike
WOLFMANmike's Avatar
i agree with Markeb ^^^^^^^^^^^^
WOLFMANmike is offline   Reply With Quote
Old 05-21-2015, 06:49 PM   #10
1963c-10
1963c-10's Avatar
Have you taken the mounting bracket off to see if theres any id there?
I definitely agree the red post should be the pos
Old 05-21-2015, 07:29 PM   #11
jayoldschool
Moderator
Maybe... 12V+ on the red post (and the light lead), coil+ on the + post, ground on the - post... just thinking out loud.
