Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-30-2015, 10:35 PM   #1
rickywideglide
rickywideglide's Avatar
1996 4.3 intake manifold gkt. replacement
found a few links on here about replacement, any one have any tips or know of any other good links? read you can replace just lowers so you dont have to mess with spider injection any help would be great, thanks
rickywideglide is offline   Reply With Quote
Old 06-12-2015, 06:16 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 1996 4.3 intake manifold gkt. replacement
wow, I gotta check in here more often
yes, you can do just the lower but you are missing the chance to get ahead of the game on vacuum leaks. FelPro sells the kit with upper stuff included for a reason. Get the ones that have a part number ending with "T" as they have the metal frame gasket. Check surface around coolant ports for pitting and get machined if it's excessive.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-15-2015, 11:36 PM   #3
rickywideglide
thanks for the reply,got the felpro kit replaced maniflod gaskets, still had a leak, turns out it was upper hose, but the gaskets did look pretty bad so at least i have piece of mind
