06-02-2015, 11:55 AM | #1 |
wheel lug nut torque
I read that if you over tighten lug nuts you can damage the rotor. Is this true? I've always just used an air gun. Am I over tightening? What is the correct torque for lug nuts (2wd)? I can't find it anywhere except for newer trucks.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
06-02-2015, 12:29 PM | #2 |
Re: wheel lug nut torque
I have always used a torque wrench. When I was growing up my dad wouldn't use one, he replaced rotors about every 3 months! He still won't listen to me. I can go years without replacing mine.
06-02-2015, 01:51 PM | #3 |
It's a good idea to use a torque wrench. The Autozone vehicle information says my K5 Blazer torque should be 120 pounds, but I don't usually go over 95.
It's also important to torque the lug nuts correctly. I took a vehicle to a tire shop to have all four replaced, and I asked them to make sure they torque the lug nuts correctly. The manager said, "Of course. We use a torque wrench to check them all." Then I watched as a tire tech used an impact to run the lug nuts tight (probably somewhere north of 250 ft-lbs) and then clicked each one with a torque wrench. |
06-02-2015, 03:54 PM | #4 | |
06-02-2015, 08:04 PM | #5 | |
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
06-02-2015, 08:08 PM | #6 |
I just use my old cross lug wrench and torque evenly. Its supposed to be 95 ft lbs by the book.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
06-02-2015, 08:10 PM | #7 |
Moderator
One more point: the threads are spec'd to be dry. No lube. No oil, no grease, no anti-seize, etc. Using any lube means you are over torquing by a substantial margin (actual compared to indicated).
06-02-2015, 08:47 PM | #8 |
Who lubes their lug nuts??
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
06-03-2015, 01:10 AM | #9 |
18 wheelers use anti seize on the stud to keep it from rusting on and some people try to do the same on regular vehicles.
06-03-2015, 10:00 AM | #10 |
Thanx to all. Lots of good info.
06-03-2015, 10:16 AM | #11 |
I use anti-seize on all my lug nuts, and doing so will not over torque them. Lubricant will give a more accurate and consistent bolt stretch, and that's why head bolts/studs must be lubed before torquing. I torque all my 1/2-20 wheel nuts to 95-100 ft lbs. The anti-seize also helps in preventing galling and corrosion because wheel nuts are used in a haesh conditions especially up here in the snow belt.
06-03-2015, 10:25 AM | #12 |
Buy decent rotors. I've never had a rotor warp from incorrect lug nut torque specs. Imagine the poor guy out there somewhere with a flat tire, no torque wrench and no cell service obsessing about whether he should change his tire or die a slow death waiting for a passing motorist with a torque wrench.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
06-03-2015, 10:46 AM | #13 | |
I never do anything more than just run them down to contact with my ½" impact.......then tighten by going in a cross pattern.......never had a warped rotor or any other kind of issue. I do spray with a little penetrating lube or WD40 just to prevent galling the threads....... |
06-03-2015, 11:31 AM | #14 | |
Moderator
06-03-2015, 12:27 PM | #15 | |||
Charlie Daniels w/ a Tq Wrench
If you are lubricating your threads, which is not totally a bad idea in harh environments, you should be reducing your applied torque by roughly 20% to get the same tension on the bolt, which is truly what you are trying to attain, torque is just easier to measure.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
06-03-2015, 01:05 PM | #16 |
I pretty much run 95-120 depending on the application. My cadillac specs at 155ft lbs and it doesn't have warped rotors...
I've never dealt with warped a rotor from lug nut torque. riding the brakes or a stuck caliper is another story. |
06-03-2015, 02:35 PM | #17 |
Longest thread I've ever seen.........discussing nuts.......
06-03-2015, 10:21 PM | #18 |
It's pretty nutty...
