06-21-2015, 03:45 PM | #1 |
Rear frame damage. Can I hammer out?
Soooo. After removing bumper and body mounts it appears that she's been tagged in the rear. Looks like PO tacked some weld stock to compensate for the damage.
Problem is rear body mounts are bent too. It looks like it's fairly minor and the rest of the frame is solid and straight. I'm not a metal or frame expert. Can i just hammer out bends? Or am i making it worse? Notice the kids pool tube....You never know when that will come in handy during the build. |
06-21-2015, 11:26 PM | #2 |
Re: Rear frame damage. Can I hammer out?
You mean notice "YOUR" pool tube!
Does it look ok on the other end of the x-member??
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
06-22-2015, 10:00 AM | #3 |
You will most likely need a little heat, but it shouldn't be much of a problem to fix.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-22-2015, 10:29 AM | #4 | |
......but I digress. Stupid question alert...Where -is the x memeber? |
06-22-2015, 10:31 AM | #5 |
06-22-2015, 11:30 AM | #6 |
Be careful, a lot of fuel lines in the area, could you get a porta- power in there
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
06-22-2015, 11:35 AM | #7 |
06-22-2015, 11:49 AM | #8 | |
Don t forget the vent canister mounted in the bed topside Good luck!
06-22-2015, 12:24 PM | #9 | |
Or are you recommending heating and then somehow using pump to straighten? Sorry for the newbie questions. |
06-22-2015, 12:35 PM | #10 |
[QUOTE=jaros44sr;7217678]That's a tough call, because you won t be able to remove them without damage, I don t think. If it was me, I would err on the side of caution and get rid of any fumes. At least get rid of the lines up to the rubber hose under the passenger seat, and do the work outside
Don t forget the vent canister mounted in the bed topside Good luck![/QUOTE/ Okay thanks, I'll do that. The vent canister in the DRside qtrpanel was removed too for repair. Thanks for the safety tip! |
06-22-2015, 02:32 PM | #11 |
I see a fair amount of stretched metal there. You're going to need a regular torch. I don't think doing it cold, will net you much success.
06-22-2015, 04:09 PM | #12 |
You would have to be creative, build a immovable wall, the bottom of the frame would be easy, since you could use the floor to push up on. But as Turp says ( he's the pro) use a torch first and see what results you get. Last resort, buy a frame section, and have that welded on. There s one for sale, on the parts board. Keep us posted on your progress
