06-21-2015, 11:17 PM | #1 |
Swiss cheese radio cut out - need ideas
The moron I bought my truck from had an 8 track in this thing, however it was cut long before he had it. I plan to run a CD player but should I just keep something like this same setup with the bezel? A radio delete falls thru this like its a black hole. A double DIN I don't think would fit between the AC and ash tray. I do not want to weld a new dash in at this time either....
Go ahead, start the chainsaw jokes.....lol
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
06-21-2015, 11:21 PM | #2 |
Re: Swiss cheese radio cut out - need ideas
The "hole"
06-22-2015, 12:47 AM | #3 |
Why not just weld a patch panel?
06-22-2015, 01:08 AM | #4 |
X2 I'm just curious what your reason is cause that things hacked up pretty bad to fix any other way. Could maybe improve the look a little by replacing the wood trim with a trim plate you make yourself from a patch panel but I don't really think you have any good options here due to the size of that hole. Maybe someone will have a better idea.
06-22-2015, 01:16 AM | #5 |
Also feel I gotta mention calling the guy a moron for rockin the 8-track is not really a classy move bro. Couldn't stop myself. Good luck with your dash!
06-22-2015, 11:50 AM | #6 |
x3 you can either weld a patch panel or fab up something completely new. There is not much you can do with that hole otherwise.
1971 Cheyenne Big Block Longhorn |
06-22-2015, 01:13 PM | #7 |
have someone weld a new patch panel in for you
06-22-2015, 02:55 PM | #8 |
I agree. The only correct option is a patch panel welded in. Anything else is sandwiched pieces of plastic or metal. If you thought the 8-track was a bad idea.....
06-22-2015, 03:14 PM | #9 |
Keepin an eye out
If all else fails I have a Realistic 8Track you can fill that hole with...I will even throw in a Eagles tape/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
06-22-2015, 07:17 PM | #10 |
I'd scout around for an old really rusty truck and cut out the patch panel from a decent dash. If you can weld half way, set it in and let her rip. That way you go back to stock ('cept for ruining the paint) and can install a stock radio or one that fits into the stock opening.
That's what I'd do.......but I'm half crazy and the other half is stoopid!! |
06-22-2015, 07:26 PM | #11 |
Get a piece of 1/8 '' aluminum like they make road signs out of ( you can pick it up all over the place on the sides of roads, lol) and make a panel you can mount a newer radio in for now and polish it up or paint it , just do a good job and let people think you did it on purpose. fix it right ,patch or change dash later when your ready.
06-22-2015, 08:04 PM | #12 | |
The 8 track may have been put in when 8 tracks were the rage, such as in the case of my truck. My dad went to a junkyard and found an 8 track AM/FM radio and replaced the original AM radio sometime in the 70's or early 80's. I still have a bag full of 8 tracks and I had some cool tapes back when I drove the truck in the early 90's. I'm not huge on music anyway so putting in a CD player or something isn't high on my list. The dash was not cut as dad found a unit the same size as the AM radio it came with. If I had a gaping hole like yours I'd hire someone to weld that back up to original size and then find like an original radio-looking MP3 player to go back. Granted I don't own an MP 3 player myself but that seems like a good option. |
06-22-2015, 09:17 PM | #13 |
For the record I didn't say (or at least didn't mean it to say) he was a moron for the simple fact of having an 8 track. However he was a moron in general......
06-22-2015, 09:19 PM | #14 |
That's what was it in it!!! And I have a whole case of tracks including the Eagles!
06-22-2015, 09:27 PM | #15 |
06-22-2015, 11:39 PM | #16 | |
06-22-2015, 11:54 PM | #17 | |
Most of what bothers me about my truck's previous owner (dad) was what he didn't do.....he didn't have the rust properly fixed....he just sent it to a bondo happy guy that didn't know how to use masking tape during painting! LOL |
06-23-2015, 12:37 AM | #18 |
Find a stock dash repair panel like they sell them here in the parts thread, if ya cut them right all the weld needed is pretty small 4 places onlyand not in the face of the radio panel, wide enough to be welded at the bezel and glove box.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
06-23-2015, 12:49 AM | #19 |
General Motors ( AC Delco ) used a special radio size in alott of their vehicles from the mid 80s up to I know 2000. In the Crutchfield catalog it is called a size "CG". Only a few aftermarket company's make the upgraded models, also found on the Crutchfield website. Try measuring the size of your hole and if you will, post it up. I have a few old ones at my shop and I'll take a measurement tomorrow also. Maybe? cant hurt to check!
72 C/10, LWB, 5.7, Auto, with A/C F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
06-23-2015, 01:04 AM | #20 |
Other Ideas ??? Not to fond of the last pic, but You could use a diff material maybe
06-24-2015, 04:08 PM | #21 |
As an alternate try some 18 Ga cold rolled. A little shaping, a little welding and if that was done well, very little metal work before paint!
