06-22-2015, 01:51 PM | #1 |
1970 Air Conditioning Brackets Install Pictures
Hello...I am installing the A/C system on my 1970 C10, 350. It is a factory air truck with a long water pump. It also has headman headers (I'm trying to find a conversion bracket that works). I can't figure out how to mount the A/C brackets. I would appreciate close up pictures from the front and side (Passenger) of the brackets mounted. And if anyone has a suggestion about the header issue, it would be greatly appreciated. The bracket I bought from Summit Racing doesn't look like it will work.
Thanks! |
06-22-2015, 01:57 PM | #2 |
Re: 1970 Air Conditioning Brackets Install Pictures
The easier way would be to swap over the the serpentine style. Don't have to worry about the headers then. Also the hoses won't have to cross over the engine either
06-22-2015, 02:04 PM | #3 |
If you don't mind running a Sanden http://nostalgicac.com/ makes some great stuff.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
06-22-2015, 02:16 PM | #4 |
Thanks...Ive got the stock compressor (a10 upgrade) and stock brackets. Just need pics on how it all goes together.
06-23-2015, 10:07 PM | #5 |
I have '71 factory air truck, short wp is how its built.
2011 Yukon XL Denali 1994 GMC Suburban 2500 454 1971 Cheyenne Super SB 1966 ElCamino |
06-25-2015, 02:42 PM | #6 |
Pics as requested
06-25-2015, 03:01 PM | #7 |
Old member
Here was mine on my 305 TPI motor. Factory brackets. First is a full set of brackets I sold.
06-25-2015, 04:12 PM | #8 |
Here's a pic of the brackets without the pump, hope it helps. Why does everyone's first answer always seem "make it not stock anymore"? Stock rocks.
