06-23-2015, 12:44 AM | #1 |
55-59 chevy truck parts
I just have a bunch of stuff I need to move out of my garage.......call me, text me, or email me, takes less time if I get fast questions, you get fast response
inside top door trim, left and right. lower door bolt covers, vent grills brand new front engine mount rubber cushions, $4 each original black plastic vent pulls /cables $10 ea vent doors $10 ea headlight switch $15 ignition switch, 6 cyl. $25 original air filters, oil bath, one with smog hose, one without $30 ea brake drums 3 sets brake shoes and parts new shoes, one new rear cylinder, 2 inch and 1 3/4 for eliminating rear brake lock-up backing plates $15 ea rear axles, one set, R&L $75 ea rear pumpkins need bearings, complete $50 ea set of spider gears with shims $100 front axle $45 front axle u bolts and wedges $10 rear axle housing $45 inside rear view mirror, new $30 inside cab light----new $40 57 steering wheel, needs restoration, but not bad $50 gas tank $45 rams horn manifolds 2 sets $100 each set steering box for parts $35 tie rod with late model tie rod ends $50 front wheel bearings, taper and roller front hubs $30 ea original 55 horns, don't know if they work, just had them a long time. $50 735/70/15 BFG radial new, hasn't touched asplhalt still has dots on tread $75 left head light bucket $35 headlight rings 3 sets $40/set deluxe heater bezel $10 glove box door slides $19 glove box lock $10 glove box door, needs fixing a little $15 alternators, fresh rebuilt, one used, 45 amp, $45 one wire alternator $65, and a one wire kit $40 leaf springs, front $100 original jack tie down $15 original under bed heat deflector plate $10 windshield wiper transmission arms $50 windshield wiper arms (no blades) $20 little arm bracket that goes between X in front of radiator to V-8 cross bar for radiator stability $20 various cab stainless, most of it has small dents where someone tried to press them on too hard. $15 each piece. Windshield piece has hail damage hillenger512@cox.net 602-510-2519 Chris
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 10-06-2015 at 12:31 PM. Reason: sold some parts |
06-23-2015, 12:33 PM | #2 |
Re: 55-59 chevy truck parts
Hi Price on headlight switch, shipped too 91945? Thanks in advance.
06-23-2015, 01:37 PM | #3 |
any brake pedals?
06-26-2015, 03:34 PM | #4 |
Beuller? Beuller?
06-27-2015, 02:14 AM | #5 |
how much for the vent covers and vent cables?
Mark |
06-28-2015, 04:55 PM | #6 |
ok
vent covers, and plastic knob pull cables, $45 plus shipping No brake pedals but I have a clutch pedal ignition switch $30 shipped Beuller, Ferris? day off?
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 06-28-2015 at 05:30 PM. |
09-13-2015, 07:40 PM | #7 |
03-24-2016, 04:33 PM | #8 |
you still have the rear axle shafts? looking for 6 lug 14 spline
1967custom |
04-21-2016, 11:32 AM | #9 |
ok i just got the money. ill take that shorter axle shaft from you. just PM me your pp info and ill send you the address at my work so we n shiop it here. (less expensive)
1967custom |
