06-23-2015, 05:58 PM | #1 |
Softopper installed... Pics and concerns!
First off here are a few pics of the top:
Now the two areas that I think might be a problem: Is this how the window corners and outsides are supposed to be? Ain't it going to leak pretty bad!! Also if you roll the windows up with the door closed you can't get out of the truck
72 K5 4x4, 350(rebuilt stock w/edelbrock carb and manifold)/th350, 4"lift 35's, GM 10bolt rear(not thrilled)... Thinking I need some heads and a mild cam or maybe a 5.3!! Last edited by Smokey burnouts; 06-23-2015 at 06:03 PM. |
06-23-2015, 06:01 PM | #2 |
Re: Softopper installed... Pics and concerns!
My guess would be the glass for sure would go inside the top.
06-23-2015, 06:24 PM | #3 |
I agree with you but if you do that you can't get out..??
72 K5 4x4, 350(rebuilt stock w/edelbrock carb and manifold)/th350, 4"lift 35's, GM 10bolt rear(not thrilled)... Thinking I need some heads and a mild cam or maybe a 5.3!! |
06-23-2015, 08:19 PM | #4 |
Do you have the black caps that cover the top of the doors? they limit the upward travel of the glass.
72 CST 4x4 Blazer, 1 ton 70 SS Chevelle, L78, 396 Everytime someone calls your Blazer a Bronco, God kills a kitten. |
06-23-2015, 08:39 PM | #5 |
No I don't, didn't even know I was missing any. I still think the side/rear of window would get caught on top
06-23-2015, 10:54 PM | #6 |
glass goes on the out side my bestop is the same way leave the black caps on the door.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
06-24-2015, 10:48 AM | #7 | |
But your top & truck looks awesome!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
06-24-2015, 11:49 AM | #8 |
Glass goes inside, it's just a limitation of aftermarket, there is a trick though. What I do is pull up passenger side all the way, then with drivers window up 75% close door and through triangle window, reach in and roll up from the outside, then just push triangle window closed.
06-24-2015, 07:08 PM | #9 | |
06-24-2015, 11:20 PM | #10 |
What you doing with the hard top in the background?
06-25-2015, 08:18 AM | #11 |
Its lookin' like a Blazer!
grillzy has it right. Get the caps on the top of ventwing area to close that gap and your set. I have the same top as you and I've been caught in downpours several times, its not a big deal. Very little rain blows in. Looks good btw, wish I'd of went with the tinted windows.
06-25-2015, 09:03 AM | #12 |
Workin to live...
I seem to remember glass was on the outside as shown too.
Jason |
06-25-2015, 02:20 PM | #13 |
Plan is to fix it up... Needs some fiberglass work.
Where do I get the caps for the windows, looking in LMC book and ain't having luck.
06-25-2015, 02:48 PM | #14 |
ebay. about $50 shipped.
72 K5 Blazer - BCHWGN |
06-25-2015, 02:56 PM | #15 |
Thanks 👍🏻👍🏻
Guess we talking these? http://pages.ebay.com/link/?nav=item...d=131532078823 What do they screw into?
06-25-2015, 05:34 PM | #16 |
attach like this.
06-25-2015, 05:41 PM | #17 |
I just didn't see any hole's up there to screw into but maybe I just overlooked them or top of my window frame been cut off
06-25-2015, 06:23 PM | #18 |
More likely if no holes you have truck doors that have been cut. Just drill holes and screw.
06-25-2015, 09:40 PM | #19 |
I actually wondered the same thing when I installed mine so I called softopper and they told me the window does go inside the flaps. You have to roll the window down to get in and out. I thought it was dumb myself, but I'm not sure how else it could be designed to keep out rain. I personally never drive in the rain so it's not a big deal to me but most will have an issue. The instructions suck by the way. Luckily I was able to figure everything out with the limited direction. Of course he could have been wrong so who knows. Sure seems weird there is a second flap on top of the glass that flops over.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
06-25-2015, 11:36 PM | #20 |
Well guess there's a part that's not original haha
06-26-2015, 04:07 PM | #21 | |
K5drive
Posted via Mobile Device |
06-26-2015, 08:26 PM | #22 |
Looks great!
