06-23-2015, 11:00 PM | #1 |
Need an answer quick. Correct clutch fork geometry???
Ok so I need to know where the cast forks on our trucks should be pointing in the resting position? Should it be pointing towards the front of the block a little or parallel to the back of the block at rest? I have an aftermarket thinner flywheel and with the correct 1/8 to 1/4 throw out bearing to fingers distance my fork is parallel to the rear of the block. I have the stock throw out in now but I do have an adjustable mccloud. Also I am dead middle of my adjustments on my rod with a brand new clutch, should I be closer to the short side with a new clutch? I need to know before I put my 3ott with overdrive in tomorrow afternoon!
Thanks guys for any help. As always a picture is worth a thousand words with me.
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
06-24-2015, 07:07 AM | #2 |
Re: Need an answer quick. Correct clutch fork geometry???
Anyone???
06-24-2015, 08:59 AM | #3 |
You said it!
A pic is worth a thousand words! So where's the pics? |
06-24-2015, 09:07 AM | #4 |
Lol geezer do you want pics from me? I went ahead and put the McLeod adjustable throw out on it this morning and made it point towards the front of the block slightly where it's 80% of the way short. At least I have a ton of adjustment now if I need it lol I can take pictures this afternoon if you want
06-24-2015, 09:33 AM | #5 |
Pics!!
Yes!! |
06-24-2015, 09:36 AM | #6 |
I will post a couple this afternoon but I am pretty positive it's where it should be. I will take some before I stab the trans
06-24-2015, 09:37 AM | #7 |
Sounds like like you should be good to go!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-24-2015, 09:26 PM | #8 |
well not that it matters anymore but heres a few pictures. I decided to use the adjustable Mcleod TB and I stabbed everything. With one spacer seems to be my best angle, Two makes it bottom out on the bearing retainer and touch the clutch forks. I have found my clutch moves about 1.5 to 2" before I feel any real resistance as if it is engaging the springs of the clutch. I welded up all the linkages and drilled them all back out and welded up any rods with wear and milled them back down. New bushings everywhere and aligned the linkages and all I can say is WOW it must have taken 3" inches of slack out of everything. The shifter throw is like I installed a short throw shifter on the column. let me know what yall think. i can take pics of the overdrive saginaw installed if anyone wants to see it.
06-24-2015, 09:34 PM | #9 |
THanks for the pics!!
At least someday when someone does a search, they'll see what it all looks like. Hope you don't get interference on the counterweights during operation. I've heard that can be a problem. |
06-24-2015, 09:37 PM | #10 |
I dont believe I will with the Mcleod. Its a good deal longer than the factory plus I have one extra spacer in it to compensate for my thinner flyweel. MAYBE I will get lucky lol
06-24-2015, 09:40 PM | #11 |
I guess this would be a good reference for building a stroker motor and having to change to a thinner flywheel with a high performance clutch and taller or adjustable throwout bearing while still using a 3 speed saginaw with the original cast fork and pivot ball. If anyone ever has any questions just ask.
