Old 06-24-2015, 08:41 AM   #1
Rockstar80
coolant issues
So I got to work today and after sitting for 2 minutes I heard a pop coming from the engine bay and then I noticed steam coming from the hood. When I got out to check it out I was leaking quite a bit of coolant from the overflow tube. It has a new thermostat and water pump when I swapped out engines. Any ideas?
Rockstar80 is offline   Reply With Quote
Old 06-24-2015, 09:10 AM   #2
cdowns
cdowns's Avatar
Re: coolant issues
you filled the radiator to the top causing overflow typical for those who don't know how tofill the radiator correctly
Old 06-24-2015, 10:28 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: coolant issues
If there is no overflow tank on your rig... which is pretty likely... you can't fill the radiator to the top. You need to leave it 2 to 3 inches low when you fill it from cold iron...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-24-2015, 07:10 PM   #4
engineer_gregh
engineer_gregh's Avatar
Re: coolant issues
The loud pop could have been a bursted hose. If the truck just over heated I don't think you would have heard a pop. Once you refill the radiator leave the cap off so you can see the water/antifreeze circulate once the engine reaches operating temperature. If you don't see any circulation it could be that the thermostat is stuck closed.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
