06-29-2015, 04:44 PM | #1 |
Stock 454 carb/intake options
I have a freshly rebuilt Gen IV 454 with the larger oval port heads that I'm throwing in a swb k10. The truck has 4.10 gears and a TH350 transmission and it will see little else than street cruising. All I need to be up and running is an intake manifold and a carb.
I'd like to use Edelbrock's Performer RPM intake manifold (PN 7161) along with a 750cfm carb. Will this intake work with an otherwise stock engine? Thanks. |
06-29-2015, 09:20 PM | #2 |
Re: Stock 454 carb/intake options
It will. But you should look at the regular Performer as well. I'm pretty impressed about the size of the runners and it would be even better I think. On a driver, I'm still a Q-jet fan. Look into a JET.
06-29-2015, 09:26 PM | #3 |
I have an rpm intake and 770 avenger carb. Mine is a little over stock but not much. Runs great.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
