Old 06-30-2015, 08:01 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
What Mounts Work With These BBC Stands?
I'm dropping a 1969 396 into a 72 C-10 chassis. What mounts do I need for these stands? Thanks, I'm a bit confused...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-30-2015, 08:28 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: What Mounts Work With These BBC Stands?
Any '67-'71 V-8 engine side mounts will work with those. The only difference in the frame brackets is the dip at the top to clear the BB exhaust manifolds.
LockDoc
Leon
Old 06-30-2015, 10:38 AM   #3
Ironangel
Ironangel's Avatar
LockDoc
Cool, thank you Leon! I noticed my SBC 3-bolt block mounts bolt right up to the 396 block. So these stands work just like the small block stands and mounts on a 72? Looks like a larger hole in the BB stands so I'm assuming a large washer will be needed as well? Thanks again, I went ahead and pulled the trigger for $115 dollars shipped on those stands.
"Two Seventy Two's"
02 3/4 ton Express
Old 06-30-2015, 02:29 PM   #4
john
member #16
john's Avatar
As lockdoc says any will work, but the originals look like this pic. There is also a lower pad and a sleeve on the bolt like body mounts. I think they are expensive if you find them.
john is offline   Reply With Quote
Old 06-30-2015, 07:50 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
A lot of guys use small block mounts with those stands. Like you said it will take a big washer also. I am using the rubber blocks, bolts, and sleeves from my 6 cyl manual trans mounts, the fit right into the BB stands. The big block mounts are very expensive, or so I hear...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-30-2015, 09:25 PM   #6
SS Tim
SS Tim's Avatar
The Truck Shop carries the factory style 68-71 mount assemblies.
SS Tim is offline   Reply With Quote
Old 06-30-2015, 09:47 PM   #7
SS Tim
SS Tim's Avatar
Just to keep things clear. Here are the correct, one year only, safety mounts and stands for a 1972 factory big block installation.
Old 07-01-2015, 01:43 PM   #8
Ironangel
Ironangel's Avatar
Thanks for the reply's. I've already sprung for the pre-72 stands, I think I can engineer a polyurethane sandwich to lock a small block mount to the stands. Thanks again, and I'm getting a better understanding of what applies to what year. ~Michael~
"Two Seventy Two's"
02 3/4 ton Express
