Old 06-30-2015, 12:30 PM   #1
Dubs Chops
help with an alternator bracket.
Hey Guys and gals. I have a 68 gmc 3/4 that had a cracked ramhorn on it. I purchased headers for it and then realized I have nowhere to install the alternator. I have looked at some of the corvette alternator brackets but I am not sure which one would fit and don't want to have to send one back. Can someone point me to the right bracket?
Thanks all/
Dubs Chops is offline   Reply With Quote
Old 06-30-2015, 12:42 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: help with an alternator bracket.
I am using the stock alternator bracket on my 1972 C15. Engine is a 350 with Hedman Hedders. Unless your earlier C25 has different brackets on it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-30-2015, 12:44 PM   #3
cooperhw
cooperhw's Avatar
I will follow along on this as my 68 also had cracked manifolds so now has headers. I have seen low mounted brackets from Speedway that mounts down low. Not sure if they will work. on mine I am not even sure if the original motor will stay yet so haven't got that far or too concerned yet. Soon though.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 06-30-2015, 01:28 PM   #4
mike16
on my 72 the alternator bracket bolts to the front of the head. is that an option?
mike16 is offline   Reply With Quote
Old 06-30-2015, 02:21 PM   #5
Dubs Chops
Gary
did yours not bolt to the exhaust manifold? Mine bolts to the head and the exhaust manifold I believe.
Old 06-30-2015, 02:54 PM   #6
GASoline71
GASoline71's Avatar
Mine bolts straight to the head only.
Couple of pics.
Gary
Old 06-30-2015, 07:52 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: help with an alternator bracket.
Mine looks just like GASoline71
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-30-2015, 10:17 PM   #8
chisler
chisler's Avatar
Google... Tim Moore alternator bracket ..it may be what you need to go to if you have no mounting holes in the head..
chisler is offline   Reply With Quote
Old 06-30-2015, 10:50 PM   #9
chisler
chisler's Avatar
Pic of the bracket with header
Old 06-30-2015, 10:58 PM   #10
swamp rat
swamp rat's Avatar
I believe the earlier trucks had the ram horn bracket the latter had the head bracket like shown above in post 6, as long as its a short water pump engine the head brackets should work for you, you can look on flea bay, or here in the parts board, or a local junk yard for the head brackets. the bracket shown oin post 9 is headers only.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-30-2015, 11:17 PM   #11
cooperhw
cooperhw's Avatar
68's don't have bolt holes if the face of the heads like the later trucks do. I am considering swapping heads so I can get the bolt holes and the brackets.
Later,
Wayne
Old 06-30-2015, 11:30 PM   #12
chisler
chisler's Avatar
I also seem to remember the 68 came with the short style water pump and from 69 up the went to the long style this can also cause issues on V pulley alignment
Old 07-01-2015, 01:01 AM   #13
mike16
make sure you get water pump alternator ps and dampner pulleys as well because mis matched between years is a slippery slope with an open can of worms at the bottom. better to locate the exhauste manifold then to chase heads and every thing else.
Old 07-01-2015, 01:10 AM   #14
swamp rat
swamp rat's Avatar
The short water pump went till 72, the long water pump went 73 and up.
Not sure of the pullys were changed for any reason, but i think the easiest way to check would be to measure the depth of the water pump pulleys from a 67-68 vs 69-72. That said the early power steering pump pulley is different from the later i'm thinking 67 and 68, it would be a cast iron pully, the later is stamped steel.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
