Old 07-01-2015, 07:16 AM   #1
resto_rookie
resto_rookie's Avatar
Radiator?
Bought a "direct replacement" radiator from classic industries along with new core support and mounts. For some reason the radiator is about 3/4" too tall and I would have to use spacers in order to use factory style mounts. Any suggestions other than changing radiators again?
resto_rookie is offline   Reply With Quote
Old 07-01-2015, 07:24 AM   #2
chiefcfd
chiefcfd's Avatar
Re: Radiator?
You may have to trim the rubber pads. I have read on here that the repops are larger. I had to do that on my aluminum radiator. Once you get the bolts started it should squeeze into place. Also place some lube on the rubber.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 07-01-2015, 07:34 AM   #3
resto_rookie
I'm not sure that will be enough but I'll try. The bottom mounts weren't sitting down far enough either so I trimmed the core support but that didn't give me much. Thought about fabbing a top mount that covered whole top of radiator. Would I still need to put some kind of rubber between that and radiator? Thanks
Old 07-01-2015, 07:50 AM   #4
chiefcfd
chiefcfd's Avatar
Re: Radiator?
Yes, it should rest in rubber.
Old 07-01-2015, 08:40 AM   #5
resto_rookie
Ok thanks
Old 07-01-2015, 08:50 AM   #6
68panelman
68panelman's Avatar
Re: Radiator?
I would talk to CI before modifying anything, If its sold as "direct replacement" it should do that. I'm sure it cost you a lot of money, so why should it cost you more?
68panelman is offline   Reply With Quote
Old 07-01-2015, 08:56 AM   #7
resto_rookie
You're right it wasn't cheap lol. But I mounted it temporarily when I got my engine put together so I could fire it up and break it in before I got new support and mounts so I figured I would just deal with it now
