Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-01-2015, 09:08 PM   #1
656mx
91 6.2 diesel engine for parts
Pulling the 6.2 out of my crew cab and putting a cummins in. Figured i'd offer it here for parts before it goes for scrap. Still in truck and running at the moment but does have a bad head gasket or head. No antifreeze in the oil. Complete air cleaner to pan. Just keeping alt and ac compressor. $300obo pick up only
656mx is offline   Reply With Quote
Old 07-01-2015, 09:25 PM   #2
qksilver
Re: 91 6.2 diesel engine for parts
man, just bought a 3/4 that needs a 6.2.........thinking.............no I am going to stay with the plan, 454 TBI. sorry , there is just something about a 6.2/700r and that something is 26 MPG and no power!
qksilver is offline   Reply With Quote
Old 07-03-2015, 01:33 AM   #3
zaccaglin
zaccaglin's Avatar
If you decide to part it out before scrapping, let me know, I'd be interested in the injector pump, air filter box (don't need lid), and tach sensor if it has a tachometer.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 07-03-2015, 08:30 AM   #4
656mx
Parting it is a option if no one wants it. Pulling it today so I will let you know.
Old 07-04-2015, 10:22 PM   #5
Are you using the GM fuel filter/separator/bleeder?
Old 07-04-2015, 11:05 PM   #6
656mx
Nope not using it. If you want it does $20 shipped sound ok?
Old 07-05-2015, 07:27 AM   #7
Sounds good. Was this a running motor? I need this to replace a cracked one. If this one was cracked you would know if you've seen it run. Sucks in air causing start issues. It's only 20 buck but would be nice to know if you know.
Old 07-05-2015, 10:45 AM   #8
656mx
The truck ran and drove fine. Would start up instantly. Just had a bad head gasket. My ebay id is dini8402 if you would like to see some feedback.
Old 07-05-2015, 01:21 PM   #9
No, I trust you. Just had to ask. Many are cracked and if the truck came to you busted you wouldn't even know. When mine messed up I had to do the bleed-out routine anytime it sat a while. I rigged a different set-up with a spin-on for it but bleeding is messy. I've actually sold it to a guy in NH, just have to get it up there. I'd like to give this to him so he can change it back if he wants.
Price is reasonable enough for sure, so I'll take it. Could you PM your info for me to send a postal money order, if that works for you?
Old 08-18-2015, 02:44 PM   #10
656mx
Going to part out the motor. If there's something on it you want let me know. Shipping will be exactly what it cost me and I will take paypal
Old 09-02-2015, 09:42 AM   #11
zaccaglin
zaccaglin's Avatar
I desperately need the power steering mounting bracket (just broke mine), and I'm also interested in the injector pump, air filter box (don't need lid), and tach sensor if it has a tachometer.
Zaccaglin
Former Rig:
Old 09-03-2015, 06:55 PM   #12
zaccaglin
zaccaglin's Avatar
Would also be interested in the Coolant Crossover pipe.
Zaccaglin
Former Rig:
Old 09-11-2015, 10:45 AM   #13
656mx
Zaccaglin PM returned. Sorry for late response. Still have it. The injection pump is a newer reman. I'll do $150 shipped for pump, crossover pipe, power steering brackets, and air cleaner.
Old 09-12-2015, 01:29 AM   #14
zaccaglin
zaccaglin's Avatar
Ten four. I would only need the PS bracket that bolts to he pump itself. Pm me with preferred payment. I do PayPal regularly.
Zaccaglin
Former Rig:
Old 09-12-2015, 01:38 PM   #15
656mx
PM sent
Old 09-12-2015, 08:33 PM   #16
48cj2a
48cj2a's Avatar
How much for all the cruise control componets and mounting hardware? Wanting to add cruise to a 6.2 that has never had it so need everything from the harness, vacuum lines, dash module with bracket and screws, brake pedal switches and under hood pieces and IP linkage.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 09-14-2015, 07:40 PM   #17
656mx
I can only sell whats on the motor right now. I haven't got into the wiring yet.
Old 09-14-2015, 08:55 PM   #18
48cj2a
48cj2a's Avatar
Just so you know the wiring and vacuum lines are a separate little harness and not part of the factory main wiring harness. connections and linkage at the module on the intake and thru the fiewall to a black box module with bracket, brake switch, turn signal switch and a connector to the fuse box and ground.
03 Suburban Z71 Z71
Old 09-20-2015, 10:35 PM   #19
zaccaglin
zaccaglin's Avatar
Payment sent.
Zaccaglin
Former Rig:
Old 09-22-2015, 05:09 PM   #20
656mx
Payment sent.
Shipped thank you. I will pm tracking number
Old 09-26-2015, 02:08 AM   #21
zaccaglin
zaccaglin's Avatar
Received the parts today, Thanks!
However, it looks like I may need the power steering pump resistor as well.
Zaccaglin
Former Rig:
Old 09-26-2015, 09:34 AM   #22
656mx
Ok but Im not sure what part your looking for? A resistor is electrical. Let me know
Old 09-26-2015, 03:33 PM   #23
zaccaglin
zaccaglin's Avatar
Reservoir damn iPad spellcheck.
Zaccaglin
Former Rig:
Old 10-04-2015, 12:04 PM   #24
zaccaglin
zaccaglin's Avatar
Still interested.
Zaccaglin
Former Rig:
Old 10-04-2015, 04:11 PM   #25
656mx
Still interested.
$15 shipped. I can send it tomorrow if you want it
