07-05-2015, 01:42 PM | #1 |
Cluster lights/Head Lights not working - Help Please
I have a 71 c10. Have new headlight switch and just installed the new Heavy Duty Headlight Harness from LMC. Also replaced all cluster bulbs with new green high light bulbs; aal from LMC. Here are my problems. Any help will be very appreciated:
1. Upon completion of new HD Headlight Harness, headlights worked great. Then I started working on Cluster lights to determine why they would not work; they were before with the old type bulbs. Somewhere along the way, using the headlight switch - I drained the battery and had to re-charge it. But, after the re-charge - the headlights did not work. I have cleaned all of the ground connections and reattached; still do not work. 2. Is there supposed to be a ground wire coming from the gauge panel/circuit board to metal under the dash? If so, I do not have one. Anyone know exactly where I hook it to the back of the gauge panel and where to run it? 3. Also, is there a ground wire from the new headlight switch that I need to connect somewhere? Anyone know what color it is and where it should go? I have also cleaned all of the battery grounds and replaced. Also cleaned the plugs and connections for the dimmer switch and re-connected. Fuses are good. Yesterday installed new headlights just in case that was the problem. And, I have one wire with a bulb coming from the steering column that appears it should be on the gauge panel somewhere - but have no idea where it goes. And, when I rotate the headlight switch it dims the heater control light so I know that's working. As I said - any help will definitly be appreciated. Thanks, Doug |
07-05-2015, 03:17 PM | #2 |
Moderator
Re: Cluster lights/Head Lights not working - Help Please
Hi Doug,
I moved this to our electrical section for you. Hoping that some of our resident electrical experts will soon chime in. Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-05-2015, 04:04 PM | #3 |
Thank you Richard. Need all the help I can get.
My Best, Doug |
07-06-2015, 01:28 PM | #4 | |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 07-06-2015 at 01:46 PM. |
07-06-2015, 02:13 PM | #5 |
Msgt USAF Ret
Here's the switch.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-07-2015, 02:24 PM | #6 |
VetteVet:
Thank you so much for your quick replys to my wiring and light problems. Your information and its detail were very helpful. As I was in the garage last evening, I turned on the headlight switch and was fooling around with it a bit and learned that if I pushed the switch handle to the right - the headlights came on and I could dim them and brighten them. So, I concluded that the switch is bad and ordered a new one. If the new one does not work - I will return it. In your opinion, does this sound like the fix I need for not only the headlights, but also for the instrument lights? Thank you again. I really appreciate your expertise. Doug Massey |
07-07-2015, 05:25 PM | #7 |
Msgt USAF Ret
Well you control the brightness of the cluster lights with the headlight switch but the headlights don't have a dim to bright feature. They come on when you pull out the switch and shine at the same intensity depending on whether the dimmer switch is set to bright or dim.it sounds like the HL switch is your problem.
I want to clarify the grounding question concerning the headlight switch. the lug on the switch is not grounded until you turn the switch knob full to the right and then it grounds the lug and the white wire which completes the ground on the dome light to turn it on. I'm in Charleston S,C.now with a sick family member. Too bad we aren't closer.
