1971 12 bolt pinion seal P/N?
My box is off so good time to change that seal that is beginning to weep.
NAPA here lists about 5 different P/N's but not for a 12 bolt. Does it go by a different name? 6 lugs and 3.07 gears if that makes a difference. |
![]() Join Date: Mar 2003
Re: 1971 12 bolt pinion seal P/N?
Yeah, I'm coming up with the same thing, pretty sure though that what you need is the 17190. 73-80 also had the 12 bolt, that's where I got the number
Thanks, they found it under that number.
Changes over to a PartsMaster PM 8460N. |
