Old 07-07-2015, 04:28 PM   #1
ahenderson_50
4x4 not working after trans rebuild 97 K1500
I need some help here guys. I had the transmission rebuilt and transfer case taken apart for inspection (was told it was good) by a local guy and both reinstalled by a "friend of a friend". Before they were pulled the floor shift lights lit up when I shifted to 4lo and 4high. Now that they're reinstalled the lights aren't working. Transfer case is engaging just don't think it's sending power to the actuator. I pulled the actuator and bench tested it and it seemed to work fine and also check the fuse. Any idea of what I need to check? Any help advice is greatly appreciated!
ahenderson_50 is offline   Reply With Quote
Old 07-07-2015, 05:15 PM   #2
1976gmc20
Re: 4x4 not working after trans rebuild 97 K1500
There's a switch on the TC lever for the actuator and indicator lights.
I've never mucked with mine because I just rigged the front axle disconnect to be always engaged.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
