Old 07-12-2015, 11:49 PM   #1
cheepin
87 Suburban running rough
I have an 87 3/4ton Suburban. It is idling terrible. It will idle fine then jump up in rpms. If you blip the throttle it will idle fine again for a bit. Driving on the road it has a slight miss at part throttle at 35mph and lower. On interstate it is fine.
Now about a yr and half ago it was running terrible. So I did a good tune up. New plugs and wires. Helped but didn't fix. Had no codes. So I started changing sensors. Put a new (not rebuilt) distributer in. New o2 sensor,new coolant temp sensor, new IAC valve. Rebuilt the throttle body. No change finally found 2 of the new plugs were bad from the factory.
Back to current issue. It threw 2 codes. Map voltage high and o2 reading rich. Put new Map in ran better but not fixed. I don't know where to go now. Any suggestions?
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 07-13-2015, 05:06 PM   #2
Ski-me
Ski-me's Avatar
Re: 87 Suburban running rough
EGR Valve?
Rebuild TBI unit? I think there is a diaphragm in there that can deteriorate (at least in my 89 there is).
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 07-13-2015, 10:27 PM   #3
cheepin
Originally Posted by Ski-me View Post
EGR Valve?
Yeah we did all new gaskets and such in the TBI unit. I'll check the egr valve.
Old 07-26-2015, 03:46 PM   #4
cheepin
Well I haven't messed witht he egr yet. My kid decided to change the iac valve. This helped with the idle for a bit. Now it is is idling low and seems to be rich. Still think this could be the egr?
Old 08-07-2015, 03:08 PM   #5
cheepin
So finally figured this out. It was the EGR sort of. When it started running rough I had found a broken plastic vacuum line. Well I got the EGR and Mapp lines reversed. Swapped back it runs great again. Jeez
Old 08-09-2015, 09:34 AM   #6
Ski-me
Ski-me's Avatar
Great to hear, congrats!
- Jeff
