![]() Join Date: Apr 2011
How do I get a bolt out??
Taking apart my 67 GMC as much as I can before taking it to the body shop.(very little experience)..removing front fender and inner fender (PS)..was removing the bolts holding the inner fender to the edge of outer fender..as you all know the square nuts are held in place with a retaining clip..I was using my impact when one just started spinning and bolt not coming out..It's at the top and very hard to see but I can feel the clip has come loose from fender edge and distorted..I didn't use the impact anymore but did the same thing with another one using my ratchet..I cannot get a wrench or pliers in there to hold the messed up clip and nut..what can I do?? Please and thank you..
Re: How do I get a bolt out??
Depending on what tools you have access to there are several options.
If you have air tools you can use a mini grinder and 2" cut off disk and precisely remove the head of the bolt. You can drill the head of the bolt off. You can drill an access hole in the inner fender structure and immobilize the nut. If the fenders and inner fenders aren't worth saving you can make a triangle shaped cut and remove the entire section bolt included. |
![]() Join Date: Apr 2013
I just spray with PB blaster and use a visegrip and 3/8 impact. It can be tricky to get the visegrip on.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Also had fender and we'll off truck easier to get at that way
![]() Join Date: Jun 2015
If you don't want to save the bolt, you can tack weld/JB weld/super glue a nut to the top of the bolt head. That way you can get wrench on both ends.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
The way to remove bolts on stuff that tends to snap (or anything dirty/rusty) is lube, loosen a bit, tighten a bit, repeat.
You either have to get pliers on the clip nut or cut off the bolt head. |
#7 | |
#9 | |
sounds like a good time. Sometimes I might slide a hacksaw blade in somewhere and cut like hell. It could be hell but I'm sure you'll figure it out, make sure to take a break when your frustration starts to peak
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
