Old 07-14-2015, 03:23 PM   #1
AMERICAN PICK-UP
2012 l20 4.8 vortec engine and 2wd 4l60e transmission..paragould arkansas
YOU ARE LOOKING AT A 2012 ALUMINUM HEADS AND IRON BLOCK 4.8 L20 VORTEC ENGINE AND 2WD 4L60E 2WD 4 SPEED AUTOMATIC TRANSMISSION.
THE 4.8 IS THE LSX TRUCK ENGINE, IT HAS 302 HORSEPOWER AND 305 FT LBS OF TORQUE. THIS IS THE LS1, LSX, DESIGN ENGINE, ALSO KNOWN AS THE GENERATION 4 SMALL BLOCK CHEVY. IT HAS THE CAST IRON BLOCK AND ALUMINUM HEADS AND HYDRAULIC ROLLER CAMSHAFT. THE CASTING # ON THE CYLINDER HEADS ARE #799 THEY ARE THE SAME HEADS USED ON 5.7 LS1 LS6 Z06 CORVETTES... THE 4L60E TRANSMISSION IS GENERAL MOTORS 4 SPEED AUTOMATIC OVERDRIVE TRANSMISSION.
THIS WAS JUST PULLED LAST WEEK FROM A WRECKED LOW MILEAGE 2012 CHEVY SILVERADO 2WD 1500 . THIS COMBO HAS 72,528. MILES. THE SILVERADO WAS TOTALED, NOT DOING ANY DAMAGE TO THE DRIVE TRAIN. IT RAN ABSOLUTELY PERFECT.
THIS IS A COMPLETE LIFT OUT ASSEMBLY COMES WITH ENGINE, TRANSMISSION, COMPUTER, UNCUT WIRING HARNESS. ( WIRING HARNESS NOT GUARANTEED TO FIT YOUR APPLICATION). STARTER, ALTERNATOR, POWER STEERING PUMP, A. C. COMPRESSOR, ALL BRACKETS AND PULLEYS. THIS IS A DRIVE BY WIRE ENGINE. THE ELECTRIC GAS PEDAL AND WIRE PLUG CUT FROM DONOR VEHICLE IS NO CATALYTIC CONVERTERS ARE INCLUDED IN THE AUCTION. WE ARE PROFESSIONAL DISMANTLERS. NO WIRES WERE CUT IN THE REMOVAL OF THIS COMBO. ... CONSULT DEALER FOR INTERCHANGE BEFORE BIDDING. SHOULD FIT 2010-2013 CHEVY AND GMC TRUCKS...
A COPY OF THE TITLE WILL BE PROVIDED TO THE BUYER TO DOCUMENT THE MILEAGE OF THIS UNIT.
WE CHARGE $100.00 TO BUILD A SIX SIDED WOODEN CRATE TO PROTECT THE ENGINE IF WE SHIP IT. WE ONLY SHIP TO PAYPAL CONFIRMED ADRESSES. NO EXCEPTIONS. WE ONLY SHIP TO THE LOWER 48 STATES UNLESS PRIOR APPROVAL.............PRICE IS $3750.00 FOR THE ENTIRE PACKAGE...
CONTACT ME WITH YOUR ZIP CODE FOR A FREIGHT QUOTE...
AMERICAN PICK-UP is offline   Reply With Quote
Old 08-19-2015, 01:22 PM   #2
AMERICAN PICK-UP
Re: 2012 l20 4.8 vortec engine and 2wd 4l60e transmission..paragould arkansas
Bump
4.8, 5.3, liftout, lsx, lsx swap
