07-18-2015, 02:44 PM | #1 |
1989 GMC s15 - radiator fan constantly running
When I start the truck ...it immediately starts to run and than runs until I turn off...I believe it should come on only when temp. is high enough or ac is on..
Before this happened I was trying to fix ac but now ac connected is not connected any more but still fan starts immediately I turn on the truck.. temperature sensor or anything else? Where is temperature sensor located that turns on that radiator fan? Last edited by vikasintl; 07-18-2015 at 02:54 PM. |
07-19-2015, 06:02 PM | #2 |
Re: 1989 GMC s15 - radiator fan constantly running
I'm not sure of where they are with an S10/S15, but I'll move this to that area and maybe someone over there can help u out.
07-19-2015, 07:05 PM | #3 |
If it is a stock 1989 S15 fan set up, then it will run whenever the engine is running because it is a mechanical fan attached to the waterpump.
If you have some aftermarket/custom electric fan set up, then it could be the temperature switch that controls the fans is not functioning properly. Now where that switch is on your truck? I don't know, as it is not a stock set up. Start following wires from your electric fan, and you will find it somewhere. |
